ctpeterson
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I just installed said toilet in a new bath and can't get the final flush-push.It fills with power, gets to the rim (seems too high) with a strong swirl, then goes back down with no final push. It does not replace, only dilutes, coffee-stained water. I had a diff't toilet installed last month that worked fine, so it's not a venting problem. This came after sitting for years, so I pulled it back up and pulled a 2-washcloth wad thru it. After some petrified crud came out, it went thru pretty easily so I re-installed. No difference.
Is there supposed to be a hole at the front of the flush-hole for the push? Mine seems like just a depression, unless it is somehow calcified or otherwise plugged to cement-like hardness. There were some little pebbles in the bowl-rinse rim holes.
Any suggestions ? Or should I just give up and go buy new?
