9 inch rough in toilet needed... or ideas.
dhornick
Kansas City, MO
Help. I’ve created myself quite a mess. We’re remodeling a down stairs bathroom. I removed what was a fine working no problem toilet with the thoughts that if we’re remodeling we might as well do it right and do it all. However, now I find out there are different rough in toilet sizes that come standard in 10, 12 and 14 inches. As best as I can tell mine is 9 and maybe 9.5 if I really stretch it. I have called all major plumbing supply houses in the area and even the manufactures but no one evidently makes a 9 inch rough in toilet.
The all say a 10 inch might work but â€might†is an awful expensive word to bank on. Any one have any ideas? :confused:
Measure exactly how far it is from the mounting bolts to the finished wall. That is your rough-in dimmension. then, check the manufacturer's spec sheets for any toilets you are interested in. They will show how much gap there is between the toilet and the wall when installed on a standard rough-in. That is your leaway. Note, go to the wall, not the baseboard.
Move the drain, and this problem goes away.
Most 10" rough in toilets will have a gap between the wall and the back of the tank. On most toilets it is 3/4", so if you push a 10" up against the wall you can go as close of 9-1/4".
Thanks Peanut9199, this is what I'm leaning towards trying and really really hoping it works. After all there was a working toilet there before so something has to work.
