View Full Version : pre-formed shower niches
Richard S
03-11-2005, 09:55 PM
I'm in the process of rebuilding my tub surround & will be using tile. I've been trying to find the best alternative to custom building a wall niche. I had previously found out about Recess-It which I didn't want to use as others had noted that the flange protrudes a bit out from the cbu & I didn't want to mess with feathering out the thinset to get the tiles to look right. I've found 2 other products: Duk Liners & ProForm that seem to not have the same problem as the Recess-It (see attached links). I was wondering if anybody had experience with these products. All input is greatly appreciated.
Thanks,
Richard
http://www.ctile.com/DukLiners.htm
http://www.noblecompany.com/proform2.html
jimbo
03-12-2005, 08:52 AM
If you look at the installation insructions in your links, they show that you install the niche over the moisture barrier ( I would caulk this joint) then the backerboard overlays the niche flange. This will be imperceptible, and the tiles lay on a perfecly smooth plane.
Richard S
03-12-2005, 09:40 AM
Jimbo,
Thanks for the reply. Have you used any of these products? The reason I'm asking is that I'm wondering if it's as easy to tile on the products as the manufacturers claim & also, if you feel that the quality of the products is up to the task as I'm worried about water leakage. I should have been more specific in my original post - sorry about that.
Thanks again,
Richard
lajoe
10-19-2007, 06:55 PM
HI
I used them all, and I would highly recommend the preformed niches
Check this online store http://www.tiledepot.us/ the do carry them all, and you can read abut their product too
jadnashua
10-19-2007, 08:09 PM
Noble and others make some nice ones. Check out this site for some examples of things and some ideas and help on tiling things www.johnbridge.com (http://www.johnbridge.com).
