Exhaust Fan Replacement Timer
Shrapnel
Hi, I'm replacing a conventional switch in the bathroom which controlled the exhaust fan. I am placing a timer instead. Upon opening the switch box, I noticed that I only have 1 - black, 1 - white, 1 - bare ground. Therefore, I assume the source is at the fixture.
Exhaust fan is 13 Amps, therefore I figured I needed a 20A Timer (requires white neutral connection). Now, my question is, if the source is at the fixture (fan), would it be safe to use a 5A Timer (which doesnt require a white neutral connection)? If not, how do I connect the timer without access to the extra wire.
Hope this makes sense, I am new at this.
Thanks,
Is this a residential exhust fan? Also if this fan actually draws 13 amps, this will definitely be a problem with a 5 amp switch....
Chris75 said:
Is this a residential exhaust fan?
I see the sheet rock pulling off the walls and the commode lid standing straight up every time the fan is turned on.
If those black and white wires were/are connected to the switch, I would guess the black is hot and that the white carries power from the switch to the fan motor already connected to a common (white) on the other side of its windings.
Shrapnel said:
Exhaust fan is 13 Amps ...
As others have already suggested, that is very unlikely ... and here is a nice timer to consider once you get the amperage issue sorted out:
http://www.wattstopper.com/products/details.html?id=105
timer
If the timer has a separate neutral, it must be electronic, so unless you can extend a neutral to the timer you cannot use it. Why not use a mechanical timer that has a knob that turns to the amount of time desired with a maximum of say, 30 minutes?
I'm with Furd and hj on this. Any good hardware, or big box, store will have a variety of spring wound timers, with different max. durations (some up to several hours).
