View Full Version : How do you mount an outside hose bib to a stucco wall?
Verdeboy
04-14-2007, 08:17 PM
I drilled a 1 3/8" hole through 10 inches of stucco and cement block and am getting ready to install an outdoor hose bib. I can secure the pipes leading to it in the crawl space, but the last 10 inches of 3/4" pvc can move around inside the hole. The hose bib is coming right out of the stucco wall and needs to be secured so it won't move around when you open and close the valve.
I'm thinking of wrapping the 10 inches of PVC (in the wall) with pipe insulation to keep it in place, and maybe just caulking the hole around the hose bib to keep that from moving.
Is there an escutcheon type trim plate people use for this or does anyone have any other ideas?
leejosepho
04-14-2007, 09:13 PM
The 1-3/8" hole sounds a little large, but maybe the bib's flange will cover it? If so, two pieces of stainless, threaded rod with crown nuts could be pushed through the flange and the wall from the outside and drawn tight via a couple of small plates and nuts on the inside.
Yes, the hole is a bit large. Make a stainless plate, like leejosepho said 4"X4" with a hole that will just let the hose bib through. You can attatch the stainless to the wall with clear silicone caulk and some tap cons or what ever you want to use, then attatch the bib with silicone and a couple of stainless screws to the plate.
master plumber mark
04-15-2007, 07:31 AM
I do it this all the time....make the hole big.....then
If you want it to be semi pernament...
if you want it to never move.
.....go get a couple t tubes of
clear ALEX latex--silicone .for under $2.00...
As you insert the hose bib, lay that stuff on thick
all the way from the threaded part out to the front end..
simply smear it on very thick on the shaft and sort of thread it
into the hole makeing a few 360 turns ...
even with that large of a hole ..it still chould work fine...
once that puppy sets up, in a few days......its not going ---NO WHERE...
you could not pull it out of the wall with a wench
I suggest you get a good quality Woodford hose bib...
and make sure you have good fall.....
cause to change it out again someday might bring you to tears..
The first mistake would be using PVC if that is actually what you are using. Some hose faucets, called sill cocks, have a flange with opeings to fasten them to the wall.
Verdeboy
04-15-2007, 12:04 PM
Why I went with PVC:
It's cold water. It's a 30 foot run to the outside wall. It's a crawl space with a dirt floor. There's so little clearance, I have to lie on my belly to make a couple of the connections.
Why I used a 1 3/8" hole saw:
It's the only carbide-tipped hole saw I own. I already invested 25.00 on this job, having to buy a new pipe wrench and a 12 inch arbor extension, and I'm only gonna make a couple hundred on the job.
Why I'll never work in a tight crawl space again:
No light. No room to work. It's a repository for old junk, broken glass, etc.,
Have to lie face down in mud. Cuts all over my hands. Stiff neck and back. Pulled a groin muscle somehow.
Coughing up phlegm now. :(
I'll see if I can find a sillcock that can adapt to PVC. I like the idea of a flange to screw into the wall.
Wet_Boots
04-15-2007, 12:48 PM
I would use a 3/4" FPT sillcock, and thread in a long nipple (brass would be ideal, galvanized would be economical), and use 100% silicone sealant to fill the gaps, and stabilize the sillcock, in the event you have difficulty securing the sillcock flange into the stucco with screws. (I see some stucco that's backed by foam, and not really capable of support) I guess you could also use a 3/4" sweat sillcock and a foot or so of copper, in the same way. The idea is to have all metal in the portion of your work that might take some abuse.
master plumber mark
04-15-2007, 03:41 PM
if you are gonna do plumbing , you better get
used to tight crawl spaces.....
pulling muscles, spider webs, racoon junk...
its all par for the course...
why not just get a woodford,
with the palstic moutning flange to the wall
solder a copper nipple into it,
then use a 1/2 sharkbite to adapt to the cpvc...
http://www.terrylove.com/forums/attachment.php?attachmentid=5989&stc=1&d=1229972791
Verdeboy
04-15-2007, 07:15 PM
Actually, as a general handyman, I can pick and choose. Maybe I'll just skim off the easy stuff from now on (just to bother Kordts) and leave you guys to mess with the spider webs and racoon sh*t.:D
kordts
04-16-2007, 06:30 PM
And I was going to tell you to go to Home Depot to get a sillcock mounting plate, they cost less than 3 bucks. Now I won't. By the way, an advantage to charging plumber's scale, is that jobs are worth doing, even if you hack up furballs, because you get what you are worth.
Verdeboy
04-16-2007, 09:18 PM
All in fun Kordts. :p
I ended up using a 12 inch sillcock with mounting flange attached and drilled holes for tapcons. It's in there solid. No caulk necessary. This job is definitely worth 2 or 3 times what I'm going to get and I'm sure they're still not going to be happy with the bill.
Another reason for not wanting to work in tight crawl spaces:
I found a little box that I tore open to use to cover some of the mud to put my head on. Afterward, I shined my flashlight on it and it read Rat Poison!! :eek: :eek: :eek:
leejosepho
04-17-2007, 04:05 AM
I found a little box that I tore open to use to cover some of the mud to put my head on ... Rat Poison!!
Better replace it or you might end up being backcharged and with a bad reputation for not leaving the peripherals as you found them!
This is one reason why plumbers seem so expensive. This is the kind of stuff we put up with on a regular basis.
Why wouldn't you have used an approved pipe like CPVC instead of PVC?
Verdeboy
04-17-2007, 11:07 AM
I thought CPVC was required for hot water/high-pressure applications, and indoors. This application is none of the above--unless an underground crawl space is considered indoors.
