kevin86
02-07-2005, 01:55 PM
So, this is my first time ever doing plumbing work and I am installing a new kitchen sink and counter top. I have no leaks in my supply lines but my drain is a whole other story.
I am using PVC to come from the sink and to create the "P Trap"? This then connects to a steel drain pipe which goes into the wall. First of all, all throughout the connections in this drain there are leaks at all of the PVC nuts. Will this be solved by using teflon tape? I didn't use any at first.
Also as the sink drains it make a "glugging" noise for about 20 seconds. From my research I am guess this is either a clogged drain, or something to do with a vent. I am not even sure how to check for a vent. Can someone give me some advice of where to go from here.
