View Full Version : Replacing Shower Faucet
DrewAltemara
02-08-2007, 01:36 PM
We have two brass faucets in the shower that control hot and cold water that were installed about 15 years ago. These are in a tiled shower.
How hard is it to replace these old faucets with new ones without tearing out the tile? We are wanting to go to the brush nickle look.
I believe these are Delta fixtures. If you have to remove the tile how hard would it be just to replace the handles.
Regards,
Drew Altemara
leejosepho
02-10-2007, 09:45 AM
Replacing faucets will require opening the wall on one side or the other, but replacing handles should be a simple job if you can find the ones you want and if they will fit your existing faucets. Many hardware stores and plumbing departments have a selection of handles and other DIY accessories and parts, but you might have to look around a bit to find one with items that will work with what you already have.
02-10-2007, 02:53 PM
YOu can check, but I would doubt that Delta makes a brushed nickle trim for that model of valve. It is not one that the designers would normall pick for a custom bath, so there will be little if any demand for it, even if Delta should make it.
DrewAltemara
02-10-2007, 05:05 PM
Thanks gentlemen. That is what I thought. I am going to see if I can find some "silver handles" that fit.
Regards,
Drew Altemara
Cass
02-10-2007, 06:56 PM
What mod. Is it 1700, 1400, 1300?
I just installed new SS trim on an old 1700 valve. The new trims will fit the old valves. The new cartridge that comes with the kit won't.
The SS trim looks like brushed nickle.
DrewAltemara
02-11-2007, 11:09 AM
Great to hear and know. I saved all my receipts when we remodeled 15 years ago with the "brass look". I'll have to look up the model number.
Thanks,
Drew Altemara
master plumber mark
02-11-2007, 11:40 AM
I still have tons of 1500 chrome
and polishe brass trim kits laying
around .... they never go bad. ....and never spoil ....
all form the early 90s...
too bad the polished brass look
has gone downhill...
ladies are a pain in the ass when fashion and tastes change...
as far as changeing them out its a fun, fun
job sometimes.. but it usually can be don through
the front through the small space provided
