View Full Version : Fiberglass tub is starting to flex
kalenwright
02-07-2007, 10:43 AM
I have a one piece fiberglass tub/shower. I just noticed when I took a bath the other day that it was flexing when I moved. I thought it was going to crack or something. I did a little investigating and noticed that the tub has a support that runs the length of the tub on both sides. However, I don't think there is any support in the center. I went to ********* and they suggested a spray some expanding foam underneath the base. Last night I opened up the access panel to the hot and cold valves and tried to see if I could see under the tub. There appears to be a reinforcing brace across the width, but does not make contact with the floor (about an inch clearance). I proceeded to spray the foam under the base using a 5 foot piece of plastic tubing. The problem is I can't see how much foam is being released. Therefore, I can't see how much the foam has expanded. Do I just keep sparaying foam underneath everyday until the flexing stops or do I just call a plumber. I'm a big guy about 240 so I'm very concerned. I a take a shower it flexes but it does not sound like its going to crack. Any suggestion would be very appreciated.
Thanks
leejosepho
02-07-2007, 04:22 PM
You definitely need(ed) to do something there, and I suspect the foam was not the best idea. The bottom of a tub needs a solid foundation, and that foam is easy to crush.
I would stop spraying foam and find a way to get something solid under your tub before its bottom cracks through altogether. That happened to me a couple of years ago, and I ended up cutting out the bad part and glassing in a new bottom. The work you need to do (or to have done) might be difficult, but the alternative is the complete replacement of a bottomless tub.
wes-in-nc
02-10-2007, 04:33 PM
I think your tub should have been set in motar when it was installed for support. Its gives it a solid feel when your in it. I agree that the foam will only crush under your body weight. Is the access panel your only means of access?
