View Full Version : Shower & bathtub Forum & Blog
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27
  1. Noble Freestyle Linear Drain - PVC or ABS?
  2. Mobile Home Baths - one down one to go,,,, Tub Surround Question
  3. Preferred Makes/Models - Tileover Access Panels
  4. Shower stall replacement
  5. Need assistance of tub/shower location (and type)
  6. Tub diverter with default shower operation, is there such a beast?
  7. Curbless shower rough in
  8. Delta 600 series hairline crack?
  9. Best location for air tub access panel, front or floor?
  10. Shower Door Glaze/Spline
  11. replacing tub/shower-need a tub that will fit in a limited space 60"x 30".
  12. Delta 600 or 1600 series shower valve
  13. Delta 1500 to 1700 sleeve too short
  14. 1950s tub drain mechanism fell apart with age...how to repair
  15. Where to mount shower valve?
  16. Neet advice on replacing old shower plumbing
  17. Bathroom remodle plans what do you think?
  18. Mystery Tub Shower Valve. What trim do I use?
  19. Raised shower?
  20. Procedure to bullnose porcelain tile
  21. SpiderWeb II - Review of Custom Building Products new Uncoupling Mat
  22. Building shower pan on concrete floor
  23. Cement board dilemma...
  24. Delta Custom Shower
  25. Kerdi Board Shower Niches - Review of Schluter System's new shower ready made niches
  26. Roofing nail for bathtub install, rust?
  27. looking for oval continuous shower curtain rod
  28. Whats this adhesive plastic this guy is using in this video?
  29. How big, if any, should the gaps be between cement board when using for tile backer?
  30. Whats the difference between thin-set mortar and latex mastic? Whats more common?
  31. How to plumb 3 port diverter for shower, handheld or both
  32. Thinset expiration dates
  33. Twisted valve body on Delta Monitor shower faucet
  34. Kohler Mixer Valve replacement trouble(s)
  35. American standard bathtub drain leak
  36. Connecting Shower Drain to 4" Iron Pipe
  37. kohler tub spout replacement help!
  38. Tub Spout Diverter Dilemma
  39. Gutter Shower Drain - A Columbian trench or gutter drain install
  40. Identify Faucet
  41. Jammed shower faucet after cold weather
  42. Bought new Moentrol refurb kit
  43. Walls not plumb...
  44. Use a pressure balancing valve and ball valves for shower controls
  45. Linear shower drain gap
  46. First time poster. Need help with tub fixtures!
  47. PEX for shower plumbing
  48. Dual showerhead question
  49. Pipe leaking behind shower..help!
  50. American Standard shower valves/integrated diverter-can you identify model?
  51. OLD tub faucet replacement HELP!
  52. Shower pan installation
  53. Shower pan installation with backer board
  54. New shower arm
  55. Help identifying shower valve
  56. PLEASE HELP! Moen shower faucet help. Chateau, vs New/Old Legend.
  57. Dev's bathroom remodel
  58. Alignment of Moen plaster ground (single handed shower faucet)
  59. 1/32 inch gap between enclosure walls and receptor
  60. 1/32 inch gap between enclosure walls and receptor
  61. Help Identifying Single Handle Shower Faucet Brand
  62. How to fix leaking pre-fab shower drain?
  63. Help with shower valve cartridge replacement
  64. "proper" method of bullnose around tub/shower surround?
  65. Shower in the basement, do I dare?
  66. Shower valve screws keep coming loose!
  67. Question about finish on kohler castiron tub drain pic attached
  68. Kerdi Shower Tray ST Subfloor Requirements
  69. How attach a new shower body valve
  70. Recommendation for a 60x42" bathtub with a non-slip bottom
  71. Pressure Balancing Valve
  72. Stuck Grohe Cartridge Part # 07-147-000 Finally, Finally solved!!
  73. Connecting smaller bathroom sink drain to a large P-trap?
  74. Bathtub Install With Mortar
  75. Bathtub drain need "p" trap? Septic smell
  76. Altmans Suite 10 Tub Faucet
  77. Shower leak, now pressure issues (Delta monitor)
  78. Epoxy floats
  79. Need help with shower cartridge
  80. need help estimating some tile work
  81. Tub and Shower remodel - fixture valve choices
  82. Total Meltdown - Any Help Out There?
  83. How to raise Tub Waste Shoe in New Installation
  84. Shower surround - horrible mess with silicone caulk
  85. Backer board for shower grab bar (fiberglass surround)
  86. Outside Tile Mitered Joints - Weak Spots
  87. Pressure balancing manifold for shower head and handheld sprayer out of CPVC?
  88. Peerless Shower and tub Faucet wall Mounted
  89. What's the secret sauce on manuerving a Drop in Cast Iron Tub
  90. How much "out-of-square" is OK?
  91. Advice dealing with plumber -- Aquatic Tub Leak
  92. How to adjust water pressure at Tub on this Moen Faucet
  93. Kohler transfer or diverter valve?
  94. Building a new master shower with antique-looking exposed copper plumbing
  95. How to cap off unvented bathtub/shower drain in basement
  96. Anybody else paints/seals the Hanging Brackets
  97. Recommend a whirlpool tub for tub/shower combo?
  98. Deck Mount Tubs not Meant for Showering ?
  99. Connection of Water Intake Pipes to Shower Valve
  100. No cold water in shower
  101. How to connect Valve to Transfer Switch When 9/16" off!
  102. Help with changing Price Phister knob to Moen lever tub handle
  103. Shower Spa balancing loop
  104. Garden Style tub spout hand sprayer ?
  105. Grohe 47 111 thermostat valve/thermoelement cartridge doesn't let cold water through
  106. Installing a new Moen Posi-Temp shower valve
  107. Help?! I am regrouting the shower and found caulk under grout, tiles falling off
  108. Schluter Kerdi Warranty Extended
  109. Sometime in the future - Schluter Ditra with integrated heating mats
  110. help with identifying plastic stem
  111. Symmons Temptrol tub and shower faucet
  112. American Standard tub/shower faucet 1960s, Push-Pull
  113. Shower Framing Repair
  114. Can anyone Identify this?
  115. Correct method for connecting to a 4 Cast Iron shower drain?
  116. Stuck! Unsure of brand... cold water side not turning on
  117. Demo'ed shower, need help with mystery pipe
  118. How to plug a shower hose with a decorative trim
  119. GreenSkin Flooring's Anti Fracture Membrane - Anti Wicking design by Devcom
  120. Pressure Balancer problem
  121. How do you center an offcentered shower drain
  122. Building a P-trap
  123. Quikrete All-Purpose Sand or Play Sand
  124. shower diverter knob not working
  125. What is the proper way to lay down 1/2" Radiant Heat pipe? - Looking for perfection
  126. Bath tub alcove
  127. Price Pfister ox8-310a
  128. Run dedicated 3/4" pex to master shower?
  129. Low hot water pressure in bath tub
  130. Will "steam showers" replace "rain showers" in high-end bathrooms? Is there a trend?
  131. aqua defense over mud pan
  132. Patch and painting an 100 poured concrete foundation wall.
  133. Shower started losing all pressure recently
  134. Installing new tub and surround in bathroom
  135. Help identifying a Moen bathtub valve brand
  136. shower to tub conversion
  137. Shower head dripping when tub spout is on
  138. Help with Price Pfister valve knob to handle conversion
  139. Westbrass Shower Drain D206B-LA Installation Instructions
  140. Water Column Installation
  141. Need a new cartridge for shower and not sure of the brand
  142. Converting an old Adobe Wall into a new tiled shower wall - How to plan step by step
  143. Where to install a hand shower with bar?
  144. should I change the p-trap?
  145. custom shower
  146. Buying material from the big box stores. Good idea or not? Top five reasons not to
  147. advice on best way to get drain pipe to fit in new shower pan
  148. Back Butter Buddy - Tool Review
  149. Extension for tub drain linkage assembly?
  150. Steel tub tear out / Kohler Villager install - Alcove - Block Wall
  151. Marble Tile for your shower - The characteristics of a successful installation
  152. Design Considerations for Steam Showers - When incorporated into a pool house
  153. Too late to switch to kerdi?
  154. Ugh. Tapping into sanitary T below basement slab.
  155. Thermostatic Valve Setup Help
  156. Drop in tub and shower?
  157. Top Ten Designers on Houzz.com - Bathrooms and Showers
  158. How to choose a right bathroom faucet ?
  159. Connecting to CI P trap in slab/sealing hole
  160. Moisture barrier issue
  161. The Best Father's Day Present? - Something our kids can afford. List of Ideas
  162. Is caulking necessary?
  163. 3 Handle Shower diverter no longer working correctly
  164. Preparing durock for spray- on texture
  165. How to make sure shower arm is not leaking inside of wall
  166. Old Leak Under Tub, Mold Issues
  167. 42" x 60" Gel Coated Fiberglass Shower Pan - Florestone #4260F
  168. Installing Sterling Ensemble shower and drain question
  169. Plumbing Advice for steam generator drain
  170. Need help Identifying a Shower Valve
  171. Incinolet Toilet - No Plumbers needed
  172. Crack in new Vikrell shower wall flange
  173. Stuck Moen shower stem valve
  174. Moen T4111 Faceplate Off Center
  175. Tiling directly to Exterior Glue Plywood (EGP) - Tiling Tips Pros and Cons
  176. Shower Rise with no PEX
  177. connecting a diverter
  178. mixing chrome finish from different brands
  179. Help selecting a tub!
  180. Should I seal shower faucet between the escutcheon and the sleeve?
  181. Quick question for a plumbing greenhorn, Moen Posi-Temp
  182. HELP!...Leaky Bathtub faucet even after I replaced both cartridges
  183. Delta R10000-UNWS Valve
  184. showpan info
  185. Kohler Bellwether Cast Iron Tub--Are the Grooves on its Floor a Negative?
  186. Old Delta Valve replacement help
  187. PP Crown Imperial interchangeable with Crown Imperial?
  188. 3-Piece Shower Drain w/Liner - Leaking
  189. Bathtub three faucet stem removal
  190. Is there a tub/shower unit good for a rental unit?
  191. What is this?
  192. Wood Framing and Tile Failures - "What went wrong and why" - Investigating Reports
  193. what brand is my Thermostatic valve???? Please HELP
  194. AS3740 Waterproofing Showers
  195. type of p-trap for tub drain
  196. 3/4" or 1/2" thermostatic valve
  197. Shower Drain Leaking from Unsupported Shower Base
  198. unable to identify bathtub faucet
  199. unable to identify bathtub faucet
  200. ANSI Shear Testing Procedures:
  201. resetting a drop in tub
  202. 1/4 HardieBacker Board for Walls?
  203. Do "L" shaped shower rods make for a reliable shower design - Small, Corner Shower
  204. Help: Shower faucet and valve
  205. American standard bathtub faucet
  206. Plumbing Multiple Heads, some questions
  207. Shower handle part identification question
  208. 3 handle tub/shower rebuild
  209. Traditional Shower System vs Schluter's Kerdi Shower System - Which dries faster?
  210. Delta install with no hot water URGENT
  211. Quick question about shower drain...
  212. Brass adapter stuck with pipe inside
  213. Building a Barrier Free Bathroom - Slab on Grade (Negative Forming and Rebar Steps)
  214. Flushing a Hot Water Tank and leaving it off for extended periods. Good Idea or Not?
  215. Can't locate replacement shower diverter
  216. Need help idenifying shower valve
  217. Need help identifying cartridge, Price Phister 974-042
  218. Shower for very different stature people
  219. replacement shower handle with hex adapter???
  220. Air Bubble Tubs and Water Temp
  221. New tub installation: is 1/2" plywood OK?
  222. Old shower faucet cartridge won't go back on/Think somethings stripped. Help Please.
  223. Shower diverter broken! Need help identifying model. Danze "Parma"
  224. 1/2" or 3/4" tub valve?
  225. adding spray foam under installed tub
  226. Cold Water in Tub/Shower Diminishing. Please Help
  227. New tub without a non-slip surface
  228. What to do... Tube replacement or refinish, cast iron vs americast
  229. ADA shower in too small bathroom
  230. Stuck tub drain fitting!!
  231. Shower Drain soldered to ABS
  232. Kohler Tub Refinish or Replace?!
  233. tub + shower + handheld valve
  234. Steam Room Approved Light Fixtures - Recommendations
  235. Removing a shower pfister valve
  236. help, what to use for under bathtub
  237. how to repair grout in shower
  238. What shower valves are these? Grohe & Danze
  239. Tub/shower pics
  240. Drop in acrylic tub placement against wall - would resemble alcove?
  241. Advice on new shower faucet/valve kit
  242. Bypass Shower Door- Bottom Track Not Sitting Flush
  243. Clawfoot tub installation with pex stub outs
  244. Shower faucet, what brand? Broadway collection
  245. Need help desperate!..ONE BATH HOME!!
  246. Tub Faucet Leaking After Many Replacements
  247. how to remove the stem from a bath tub faucet
  248. Plumbing Shower Valves
  249. Can't locate replacement shower diverter (Pic attached)
  250. Tub/shower valve installation with 2x3 studs
