View Full Version : Toilet Forum discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25
  1. Who Made Sears Brand Toilets In 1980?
  2. How to change water inlet and shut off valve completely?
  3. Best dual flush toilets?
  4. Which Toto toilet for my small bathroom?
  5. How Safe Is Riddex, Rid-X
  6. compact elongated toilet recommendations?
  7. Brand New Gerber Install Won't Flush
  8. What is a "full flush" on ultramax
  9. New Drake – Inconsistent Refill
  10. Closet flange distance questions(sink, side wall)
  11. Royal Monterey 1009 dual flush toilet
  12. Sitting on the lid of a toilet
  13. Dual Flush Reviews
  14. HELP! Kohler Wellworth clogged--for two days
  15. Will Round-Bowl Eco Drake do the Job?
  16. Buy Loo online or try luck w/ boxstore?
  17. Hospital Toilet Question
  18. Soiree and supply line question...
  19. I have a toilet that was installed in my house in 1988
  20. Eclipse (St. Thomas Creations) Marathon
  21. Flange Extender, necessary?
  22. Toilet Flange in 1959 built home.
  23. One toilet 12" Rough-in, other 2 are 13.5"
  24. advice on toilet for kids?
  25. Remove flange to replace underlayment?
  26. Raw space needs bathroom instalation - costs involved
  27. wet venting a tub into a toilet line
  28. Confused over Toto Drake options!
  29. St. Thomas Quattro
  30. which stays cleaner?
  31. Home Depot or supply house ???
  32. Tank Bults Either Rusting or Causing Rust
  33. toilet slow to evacuate and slow to fill up after plumbing work done
  34. Drake vs Aquia Toto
  35. Cloudy Water in Tank After Refill
  36. Did I just buy an old Toto Drake?
  37. Toto Drake slow to refill
  38. Toto GMax Flush system problem
  39. Toilet Tech
  40. Soiree MaP scores?
  41. toto fill valves
  42. No Splash from Toto Gwyneth
  43. How deep is my rough-in? (pic)
  44. Plunger recommendation for Am. Std. Champion?
  45. Ultramax questions
  46. BrassCraft Fillpro Fill Valves?
  47. Korky 528T for 1.28?
  48. Colors
  49. Toto seat
  50. Wax ring
  51. 11" rough-in
  52. Size of Toto Drake base?
  53. Fluidmaster..won't completely flush
  54. Toilet over joist help
  55. What size tank is AS 4040?
  56. Toilet Flange
  57. pump sewage uphill... only 10' up and 200' away
  58. toto toilet dimensions from pipe to front
  59. Pressure toilets & pressure loss
  60. Duravit Flush/Fill Valve Replacement Parts
  61. Running toilets: A flood risk?
  62. toto drake trip lever
  63. Flushing comparison
  64. Basic wax-ring question
  65. Assistance ASAP please
  66. Metal flange
  67. Closet flange height
  68. Can this be repaired?
  69. Quality Trip Lever Replacement for Drake
  70. Is 1.28gpf Enough Water?
  71. need for lined toilet tank?
  72. quiet toilet
  73. Success
  74. Why is this advice given
  75. Finicky Flusher
  76. Correct term for this type of toilet?
  77. Toilet tank drop ball - red plastic tip
  78. St Thomas Palermo 1 piece comfort height
  79. Eljer Titan....Not bad for a big box toilet.
  80. 25 1/2 inch long toilet needed. Any ideas?
  81. toilet clearances to wall and tub
  82. Eco Drake Insulated?
  83. Toto Drake vs. Eco Drake & Unifit Adapter
  84. Street 45/45 closet flange vs. spigot closet bend
  85. rusted flange, advice pls
  86. Nexus - 11.5" Rough-in - 5/8" Thick Baseboard
  87. Lamosa Sahara Sasa Tank Cracked
  88. Need to find 5 gallon flush toilet
  89. TOTO Clayton toilet reviews
  90. HD Toliet 1000 MaP - Horrible reviews?
  91. Eljer Flush valve replacement
  92. Toto for 10" rough in?
  93. Toto Eco Drake - loud flush "finish"
  94. Help!!! Soiree Eco 1.28 vs. Soiree 1.6???
  95. Toto Eco Drake No Longer Flushing Properly
  96. Two-piece Gwyneth tweaks
  97. A dumb mistake on my part
  98. Tank to toilet gasket with two holes on side to hold tank
  99. Le Bijou toilets?
  100. gift that keeps giving =o)
  101. 1 piece version of Drake?
  102. What's the advantage of an elongated toilet?
  103. Toilet Flushing Problems
  104. Best ADA toilet needed in home
  105. Toilet isn't flushing well. Bowl fills too much, (& BUBBLES), then drains gradually
  106. Toto Flushing System Confusion
  107. Toilet and tile
  108. Please Help Answer Some Toilet Questions!!
  109. Eljer Titan versus Toto Drake, or Kohler Cimarron class 6
  110. Toilet rough in is 11 1/4"
  111. Briggs 6006 Leaks while filling
  112. Toto Guinivere bowl wash
  113. Toto questions
  114. Best Washlet?
  115. how to remove this toilet pipe?
  116. Is it OK
  117. Front of Ultramax tank broke off. Can it be fixed?
  118. low flush/high efficiency toiles with 14" rough
  119. insulated
  120. Toilet Odor?
  121. Toilet for Elders
  122. Remove bowl to replace seat????
  123. UPC toilet top lever
  124. Toto Plunger?
  125. Loose Toilet Seat Cure
  126. Guinevere Trip lever/arm installation
  127. backyard toilet
  128. Drake? DrakeII? Ultramax? Other? Could use a clue...
  129. Any Toto model with bigger seat openings?
  130. One2Flush on a Toto Drake
  131. Toto Ultramax running problem
  132. New closet flange, still leaking, help please
  133. How to vent duravit/geberit wall hung toilet
  134. Plumbing Rough In
  135. Toto Aquia vs Toto Ultramax
  136. CI flange too high and no riser to work with
  137. Plastic To Cast Iron Pipe
  138. Aquia I vs II?
  139. Toilet draining
  140. Oatey's Moss Bay Replacement Flange
  141. Toto Ultramax, sound
  142. Toto seat loose
  143. Shimming a Toto Soiree
  144. Flush/No flush
  145. Dual Flush Kits
  146. Briggs/Case 3000 parts or redesign?
  147. Toto Drake, comfort height, round?
  148. Ultimate Toilet
  149. 14" rough-in for toilets. Which models take up the least amount of space?
  150. flapper drops too soon
  151. Help! Need large trapway, then get a Caroma
  152. Toilet drain removal
  153. It must a been a Toto...!
  154. Aquia II vs. Ultramax for Bungalow w/Old Pipes
  155. 10" Rough In Options
  156. Toto-Drake, Eco-Drake, UltraMax
  157. Question about Flapper for Toto Ultimate
  158. Innie or Outie?
  159. Mansfield 180 flush valve
  160. Toilet fails to refill after flush, please help! With pictures
  161. Leaking Toilet Bowl
  162. Slanted vertical waste line leading to toilet/closet flange
  163. Burping toilet
  164. Toto options for 13.5 rough-in ?
  165. 10" Rough-in with Dual Flush?
  166. 10" rough-in question
  167. Commercial Urinal?
  168. How to stop a sweating toilet
  169. Ultramax vs. Drake flushing difference
  170. baffle is loose in a 1000' gallon septic tank?
  171. Toilet Flange installation
  172. Cadet 3 FloWise (1.28 gal) with Korky WaterWise Fill Valve uses 1.6 Gal
  173. Cleaning Toto toilet
  174. Can I use a pressure assisted toilet with low/no water pressure?
  175. how much overlap on PVC for closet flange?
  176. Aquia III water tank level dropping
  177. Does double cyclone use G-max (Emax) flush
  178. Space Needed to Lift/Remove Tank Lid On Toto UltraMax II (Gwyneth 1-piece)
  179. Consumer Reports August 2009 toilet report rates American Standard Champion 4 #1
  180. Does bolt distance matter?
  181. Sams Club Dual Flush Toilets
  182. Mansfield Alto 137-160 toilet review
  183. What Does Rough-In REALLY Mean?
  184. What kind of toilet supply hookup is this?
  185. Wall mount remodel options - re-use carrier or install Geberit/Walvit?
  186. 1927 Toilet....HELP!
  187. we've sprung a leak
  188. Offset and Height issue...
  189. Need 14" rough to match AM Std White
  190. New vent or no vent
  191. vacuum occuring?
  192. mansfield ecoquantum 147-119 vs 148-119
  193. Tecsun Toilets
  194. noisy water pipe after flushing
  195. Help needed asap-need to decide now :-( KOHLER K-3611 Highline
  196. Long....and level
  197. Will Pressure Assist help Marginal Plumbing??
  198. Tight fit Toto / Drake
  199. Leaking Toilet??
  200. TOTO UltraMax II 1.28 with Double Cyclone
  201. small powder room, 4.5' wide by 4.0' deep
  202. Which is better? A factory insulated tank for the Drake?
  203. 11" Rough In Question
  204. Toilet running
  205. Toto Carrollton Flush and Fill Questions
  206. Old Toilet starts filling tank when I use the hose
  207. Ultramax seems to be running quietly
  208. Rough-in definition
  209. New American Standard Dual-Flush Reviews
  210. replace or reinforce
  211. Old House Installation Challenges
  212. Spin a Toto Unifit Adapter Around Backwards?
  213. Toto Channel on Youtube
  214. Consumer Reports Recommended toilet, Gerber DF-21-318 a big Flop!
  215. ghost flushes the toilet!
  216. All of our Toilets Burp
  217. My toto toliet with smaller flush valve (2"?)
  218. Toto Drake Uneven ???
  219. Drake - should I just shim it ? Any Ideas ?
  220. Embarrassed and don't want to give this Wellworth toilet a chance
  221. Killing the black ring..!
  222. Noise when Toilet is flushed
  223. Dalton, Carusoe or other due to tile baseboard
  224. Need Help On Leak.
  225. Mansfield Quantum One - wall mount replacement?
  226. Crane Rexmont Wall hung toilet review
  227. toilets, toilets everywhere
  228. Leak
  229. yet another toilet recommendation
  230. Old, non-standard rough in
  231. Gmax in Toto/Drake
  232. I have a screw loose.
  233. Recommendations for new toilets in Rental Property?
  234. Gerber toilet woes
  235. Kohler Highline Pressure-Lite Comfort Height toilet Review and Comments
  236. School appropriate low or dual flush? Suggestions?
  237. Eljer Canterbury continual flushing
  238. Tile not level around Toilet.
  239. Toilet Runs Often
  240. toto one piece options
  241. Best 14" rough in toilets
  242. Toilet not flushing??
  243. TOTO's made in VIETNAM?
  244. Lower closet flange?
  245. toto aquia vs drake?
  246. Allia toilet parts
  247. Promenade vs Drake
  248. ProPlunger
  249. Wall hung toilet issues
  250. Toto flapper and fill valve
