View Full Version : Water Softener Forum, problems, installation and reviews
Pages : 1 2 [3] 4
  1. Installing Used Kinetico
  2. adding carbon to resin tank?
  3. Combining Calcite and Resin Beads
  4. Kenmore UltraSoft 480 - Regenerating/Drainin non-stop - - is it worth repairing?
  5. Programming 7000SXT
  6. Coliform, Iron Treatement?
  7. Water Test? Also digital Or mech control ?
  8. Water softener & sediment filter recommendations?
  9. RO water smells like fish
  10. Kinetico Model softening 50% of time
  11. Fleck 5600SXT Programming
  12. Programming Fleck 7000 SXT
  13. Clack WS-1 CS Pricing?
  14. Filox Backwashing
  15. DIY Water Testing
  16. Questions from a man on a softener quest...
  17. Ancient Water Softener Guidance, Advice, and Spraying Water All Over the Garage
  18. Kenmore Softener Problems
  19. Help identifying Kinetico components and finding proper resin
  20. Yellow Water after Regen Cycle
  21. regen question
  22. How to install Culligan seal kit?
  23. Kenmore water softener error code 3.....help!!!!
  24. Any real advantage to soft water resin rinse?
  25. Trouble identifying and manual recharging dual tank softener
  26. float setting
  27. Do I need to test for hydrogen sulfide? (rotten egg smell)
  28. Shortage of potassium chloride
  29. Greensand Filter - Frequent Clogging
  30. Trouble with greensand filter not drawing in Potassium Permanganate
  31. Water issues....please help!
  32. how long should the resin last
  33. Discharge from drain is killing my plants!
  34. Do I need chlorine filter with Kinetico and city water?
  35. Draining Water Softener - Seasonal Cottage
  36. Brine tank almost overflowed
  37. Water Softener settings
  38. Irrigation Well
  39. New softner, tank and filter question.
  40. Arsenic / Iron - Softener and RO best solution?
  41. Need to purchase a water softener on line but need recommendation where
  42. water flow
  43. Leaking thread on softener
  44. Is this Kinetico plumbed correctly?
  45. Need Water Softener Recommendation
  46. Help with water test results.
  47. Hot Water Smells
  48. Culligan Mark 812
  49. Please help to identify a water treatment system (w photos)
  50. Sizing Question for very hard water and one person
  51. Plumbing reversed on Kinetico water softener
  52. What size for pH neutralizer?
  53. Rebedding a Culligan Carbon Filter / General Water Treatment System Questions
  54. How is softener capacity programmed or calculated with lower salt usage?
  55. Add iron out/rust out to Neutralizer?
  56. Trying to select a filter for Chlorine and sediment- before the Softener
  57. retrofit a water softner to become an iron filter
  58. drained hot water tank
  59. Turning Off Soft Water Unit?
  60. Carbon filter before or after water softener
  61. Winterizing Water Softener
  62. No Brine
  63. Hard Water Leaking
  64. Blowing Out Filter Tanks
  65. Water Softener Drain and what the Plumber told me while getting a quote...
  66. Continually draining
  67. Water-Rite Rebuild Remedia help
  68. Water softener advice
  69. Softeners and Water Pressure
  70. Softener Sizing Help
  71. Constant Water flow through water softener drain line
  72. Culligan silver not metering flow
  73. Resin tank dimensions
  74. Green Sand Filter Issue
  75. Technetic 1050 PP draw question(s)
  76. Spray vs Air Injector for Aeration
  77. No regeneration - turbine problem?
  78. hard water or soft for r/o
  79. Greensand System Installed... Low Pressure?
  80. upcharging for softeners
  81. Water hardness, city report vs home measurement
  82. Air in water line after backwash
  83. Mark 89 Salty Water
  84. Fleck 9000 mechanical control valve day override option?
  85. 3M recommends pressure tank size for their CBF100 carbon filter
  86. Culligan Medalist WS setting recommendations?
  87. Black water after regeneration....
  88. Need to break vacum in water softener drain line
  89. Iron Removal Question
  90. 3 options
  91. Newly Installed Water Softner/RO
  92. Culligan Mark 89 float adjustment
  93. New water softener install
  94. water softener drain
  95. 255 valve / 460i control
  96. Need help with fleck 2510 valve
  97. Water softener drain
  98. Softener and bacteria?
  99. Salt dose...?
  100. 4" Plastic Tube in Brine Tank Cracked
  101. Culligan Water Softener system - virtually zero water flow
  102. Recommended best settings for 6700xtr 48,000 grain water softener
  103. Whirlpool WHES30 softener issue
  104. Reserve Selection for Fleck 7000SXT
  105. Hello everyone
  106. underbed gravel question
  107. My water result and how to treat?
  108. New member here with a
  109. Fleck 7000 not softening or consuming salt
  110. Efficiency
  111. New well Water treatment. Softener with tankless RO.
  112. Kenmore water softner not drawing brine
  113. Water is salty after reffilling softner!Help?
  114. Kenmore softener won't drain?
  115. clack ws1 C1 no power
  116. How to choose a water softener?
  117. Softener ID
  118. Iron filter selection
  119. Took softener off Bypass and now no water in the house???????
  120. brine/slow rinse question
  121. kinetico model 60
  122. Cant take the effects of hard water in N. Phoenix, need help quick!
  123. How do aquasensors work?
  124. Questions
  125. Iron problem, well chemistry changing?
  126. Water Softener Installation?
  127. Water Softener Salt With Iron
  128. need softener replacement advice
  129. 7000SXT...time flashing
  130. Water softener WHES40 & Central Water Filtration System - Questions
  131. Question regarding testing treated water
  132. NE DIY'er
  133. Trickling sound in resin tank
  134. waterboss
  135. Water softener installation mistakes
  136. Where is the best place to get water hardness tested?
  137. Air from faucets after softener install
  138. please rate my plan of action..... new informed member
  139. Kinetico Water Softner 10 years old. UK compact under sink model
  140. Would it be ok to install a used Culligan Mark 412 Softener?
  141. Is my backwash Drain from Softener OK? -Pic included...
  142. Constant drip down drain valve from Culligan Iron-Cleer
  143. Repair/Replacement Options
  144. General Ionics IQ0820B won't draw brine
  145. Fleck 5600 help
  146. Yellow water after water softener regeneration
  147. Buy the Big Brands (Rainsoft, Kinetico, Culligan) or cheaper solution just fine?
  148. Top basket needed?
  149. rebed media help
  150. Water Right Sanitizer Plus - Hit 'Next' During Regen Process
  151. bottom distributor?
  152. Softener Sizing and Selection
  153. Resin in House Plumbing
  154. Softner Drain freezing
  155. Carbon foul?
  156. Air Gap Overflows?
  157. Fleck 7000 cam not depressing Brine Valve Assy?
  158. What size Fleck 5600
  159. Valve cover on water sofener blew apart
  160. Resin installation
  161. Prototype system
  162. Water too high
  163. Salt setting?
  164. Need help in choosing & sizing water treatment equipment.
  165. New house water smell
  166. Yet another sizing / option question
  167. Water Softener Start up Question
  168. Softener + neutralizer questions
  169. Aqua II 22 passed zeolite ... Why ?
  170. 5600 SXT settings
  171. Help Configuring water softener
  172. Aquacera RS-City line of whole house salt free water conditioner
  173. iron in well water
  174. Review my softener choice
  175. Still seeing a bit of resin...
  176. Acid Neutralizer Questions
  177. Confused--Really confused softener and BB install.
  178. Softener/treatment system guidance
  179. Culligan MARK 100 PROBLEM
  180. Logix 760 settings
  181. sparkling water??
  182. New softener help
  183. disaster averted !
  184. Please help with water softener sizing
  185. Water consumption increase?
  186. 2510SXT vs. 7000SXT
  187. what does setting the Grain per gallons acually do when changed to different setting
  188. A good Water Hardness test kit please
  189. Clack WS1 Draw issue
  190. pH 6.1 after softening..how can I raise it ?
  191. Water Softner - Unused for Winter
  192. Potasium Permagnate Filter
  193. Need Help Buying a Sediment and Water Softener System.
  194. GE Smartsoft model gxsf23z01 issues
  195. The Worst Water?
  196. pink water
  197. Natural alkaline mineral water for drinking.
  198. Water hammer
  199. will not regenerate automatically, Kenmore water softener
  200. Keep 13 year old Kinetico Model 60 or buy new Fleck? Opinions wanted!!
  201. Recommendation for Replacement Water Softener for 12 yr old Culligan
  202. CR100 with KDF-85
  203. Brine Level keeps rising in Master NS-10T
  204. What components would you recommend?
  205. well water lab tests, best treatment option
  206. Well water question
  207. Acid Neutralizer suggestions
  208. Overflowing when recharging Model WHES40
  209. What is an expected hardness level if a water softener is working correctly?
  210. Kinetico K-60 is discharging constantly.
  211. Whole House Soft Water System
  212. Kinetico 60 system compatible with Taco circulator pump?
  213. Proper resin tank size for 2 cubic foot softener?
  214. 3M Cuno Aquapure CBF100 'runs'
  215. Do I need a softener?
  216. water softener advice, 32K grain, twin vs single, 1" valve
  217. Resin-Tech CG8-BL vs. CGS-BL
  218. Fleck 5800SXT first install review
  219. Softner Install & Pool
  220. Three way ball valve with off position, one inch bronze, full port
  221. fleck 7000sxt Can I stop raw water bypass during regen?
  222. Twin tank: kinetico, culligan
  223. Looking for carbon
  224. Debrief of my Cr100 with KDF-85 problem
  225. Please help with acid neutralizer questions
  226. Recommendations for system
  227. Well Filtering / Softener Recommendations?
  228. Does anyone know the pipe center distance for a Fleck 5600SXT.
  229. New RO
  230. Softener/treatment system guidance, conflicting contractor bids
  231. Culligan Gold/Silver Regenerating daily
  232. Water Softener Where to Start?
  233. Low flow from Clack WS1 water softener
  234. 2 questions about softeners
  235. Junk in water
  236. Help identify resin and water softners
  237. Water softener pellets vs. crystals
  238. Rayne RXD 1500-D System will not draw brine water
  239. Recommendation for well water softener system
  240. Pentair Retro-fit
  241. Softener question
  242. Getting rid of H2S
  243. Water Softener Install with PEX Plumbing
  244. Softener vs Conditioner
  245. Iron removal
  246. My water softner is not using Salt anymore
  247. Controlling Final Hardness, salt dosage, upflow brining questions
  248. Automated Pure Water 12"x60" Retention Tank - Good stuff or BS?
  249. Central home water filters
  250. brine quantity check
