Well Pressure tank replace or repair?
WesM
MD
Hi, I have a kenmore (PN# 390.291701) 80 gallon water pressure tank for my well system. Functionally its fine, but it has developed a slow leak at the bottom of the tank, where the fitting looks like its screwed into the bottom. I have not been able to find much if any information on this tank, does anyone know if the fitting at the bottom can be replaced? Or should I be looking to replace the entire tank?
If you look at the picture, the corroded portion near the top where the PVC interfaced near the tank is where the leak seems to be coming from.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Replace the tank. Now would be a good time to update to a constant pressure system using a Cycle Stop Valve as comes in the tank replacement kit model PK1A.
WesM
MD
A CSV system is something I am considering if I have to replace the tank. Are there any special pump requirements with a CSV, or will it work with any well pump? Does the pump need a controller/VFD to work with a CSV?
This is the pump I installed in my well about 7 years ago. There is no control box on it, the pump just runs off a simple pressure switch near my pressure tank.
My water is very acidic at about 4.5-5 PH, will this have any effect on the longevity of a CSV system? what is the expected lifespan of a CSV?
On the old tank, can you try tightening the nuts 1/8 turn with a breaker bar and a 6-point socket? Just an idea, not based on experience.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
The PK1A kit comes with a new 40/60 pressure switch, which is the only controller you need. The CSV was designed to replace VFD's and has been doing so for over 30 years. The CSV1A and the fitting in the PK1A kit are Stainless Steel, which is about the best you can do when working with acidic water.
