@Valveman, I need some help.
I have a family of five.....we live in a 2-story house on well water. Water pressure is always an issue.
This is my current well water system:
• Submersible deep water well pump (not sure on specs since it was installed before we moved in)
• Well pump discharges into 180-gallon storage tank in well house. This is to vent off the sulfur gas. This is high yielding well @ 610 feet.
• 1/2 HP submersible pump (7 GPM) in the storage tank supplying the pressure tank and house.
• 20 GAL Pressure tank with a 40/60 switch.
If I want constant water pressure in the house with 2 people showering at the same time, etc. what do you recommend? Can I replace the 1/2 HP submersible pump with a Jet pump to provide more GPM? Or can I just replace it with a booster pump that will maintain PSI? What specs on the pump do I need to look for? I believe the piping going into the house is 1.25" schedule 40 PVC.
Thanks,
Drew
