Water filter suggestion
Shane11
Northeastern PA
Hi everyone. I'm looking for recommendations on a filter system with a DIY approach to treating my well water. The main issues are low ph, iron, and possibly IRB. Here are the details.
Well Info:
Date drilled 1982
Depth 150ft
Depth to bedrock 85ft
Static water level 12ft
Estimated well yield 60gpm
Flow rate 11gpm
National Testing Laboratories:
Iron .840 mg/L
Manganese .183 mg/L
Ph 6
Hardness 11 mg/L
Turbidity 12 NTU
"Test taken when water was ok"
I purchased a hach test kit and also installed a 20 inch big blue which captures the ferric iron but not the ferrous.
It seems the iron levels fluctuate greatly. At one point last summer the iron was at 0ppm. Right now they are high and looks like IRB too.
Recent hach test kit:
Iron 8ppm
Ph 6
Hardness 1gpg
After looking at filter systems online I'm a little overwhelmed with the many different tanks, valves, controls, and media available. Two online retailers quoted systems at around $4k. Can someone point me in the right direction on what to get and where to get it? I'd sincerely appreciate any advice. Thanks. -Shane
How many GPM can your pump pump into 30 psi or more? For a backwashing filter, that can be an important factor.
Shane11
Northeastern PA
I have a 30/50 switch and 1/2 horse pump. I did a basic flow rate test with a 5 gallon bucket and yielded 15gpm. Another test i did using the draw down method showed 11 gallons per minute.
So read posts on "Katalox Light"
I suspect that a filter built with a softener piston, drawing from a solution tank, would do better than the common way-- using a softener piston, but no solution draw. I am not a pro.
