I am having to re-plumb my bathroom, and am trying to follow IPC 2018 as best I can (I live in Vermont).
The current Stack Vent, which exits the roof, is 3" copper and currently only vents the toilet. As I am now replacing the toilet, and remodeling the bathroom, I figured it was a good time to open the wall and tee off the stack so the other fixtures can be vented. This is a single story home with a basement.
The part I am having difficulty with is where the sink drain is entering one side of the Double Sanitary Tee, and the toilet vent on the other side. Is this a correct way of venting? If so, what vent type would this be considered? I thought it resembled a "Common Vent", but I am not sure if the toilet vent side is considered wet when the sink drain is at the same level...
The design is rough, where the pipe lengths are for illustration purposes only. But the fittings should be according to the IPC (I hope). Here is a link to the design: https://make.craftyamigo.com/design/XhYmlsfUlTO7OuIhAAuxL5gISfq1/boyC6AeRJbU9ap56pBVb
From another angle:
Any thoughts or observations would be appreciated.
From another angle:
