UPC Code for Horizontal Wet Venting Layout
Really
Washington State
I need some seasoned advice on how to layout plumbing for a really tiny bathroom so it uses a horizontal wet vent via the lav on the right side of the building. This needs to follow UPC, not IRC.
Footprint: 5' x 4'.
Toilet: 3 inch pipe
Shower and Lav: 2 inch pipe
Septic tank: Downstream (bottom of drawing)
Vent: Must use the 4 foot exterior wall to the right
Structure: 2x6 floor joists on 4x6 beam (toilet will use a 45 degree offset flange to avoid the beam so that 3 inch pipe will come downward at 45)
I know the toilet needs to be the most downstream fixture and I need my shower to connect into my lav before the toilet comes in. I also have to keep within the 5 foot max length for a trap arm. This seems like it should be easy but I can't come up with a code-worthy design (yes I'm a newbie). Versus me sending a bad layout I thought I'd just present a clean slate for someone to start with. I'd really appreciate any help.
Update: I came up with a design where the shower runs under the toilet drain where they cross (or it could run over the toilet drain, based on where toilet exits at the 45 degree). Does anyone have suggestions on whether this looks like a code worthy design?
