Oconnellshawn88
So wondering to be sure on thermospyoning and gravity fed system. Ive got 2 water heaters that are different size. My plan was to just run loop back from the upstairs shower line being the highest and furthest away fixture. But i also have a toilet and vanity and wash machines on basement level. Since those lines will run below height of water do they require a check valve or back flow preventer and wouldnt those lines just get cold if u did put one. Still torn on using these in tandom rather than series only because of potential of not same amount of piping or btu so it ends up not working properly. But series would mean if one goes then im pretty much screwed and makes the recirculation system a lot more complicated. And dont really want a recirculation pump mainly cause of the extra use of the hot water heater and electricity and noise and seems more overall cost efficient and appliance safe. But now am not sure cause the water lines to the basement fixtures will all be in floor trusses. Which is above water heater already. So when piping back down to the basement bathroom does that screw up the entire loop?
