Sump pump installed correctly?
jeff360
New York
I recently had a sump pump system replaced, and had a couple of questions regarding the installation for the experts here:
There is a primary and backup pump in the pit, both 1/2 horsepower- one is elevated above the other (there is also a third, small battery backup pump). The two 1.5” pump discharge pipes connect at a tee (?), which outputs at 1.5”. There is then a very short run of 1.5” pipe, before a furnco adaptor transitions to the final 2” discharge line (the 2” discharge pipe on the right side of the furnco is not really visible in the picture).
With the current setup, should the primary pump be connected to the straight run of the tee, or the bottom limb of the tee?
Would it be better to replace the current tee with a connector that outputs directly at 2”, eliminating the short run of 1.5” pipe before the furnco (bottleneck)? The installer stated that because the 1.5” pipe run was very short, the throttling impact would be minimal.
Thank you very much!
Thanks very much for your reply. Every pump has a check valve and vent hole. The pump on the 90 degree limb is currently raised higher (making it the backup). Specifically to follow up, the current fitting appears to be a sanitary tee - AI tells me in that situation, the primary pump should actually be on the 90 degree limb for less turbulent flow. Do you agree? Right now the primary pump is on the straight limb instead.
I would keep the primary pump on the straight run and put the backup on the branch, since that gives the pump you rely on most the cleanest path and the least turbulence. Your installer is right that a very short 1.5 inch stub will not choke it much, but if you ever redo that joint, a tee that goes straight out to 2 inch is the cleaner setup and it removes one more restriction. Just make sure each pump still has its own check valve, or one pump can push water back through the other.
