Josh_Michigan
Hello,
I built my new house and had a new well installed last year. The breaker to the well pump is tripping once or twice a week. It only happens when I'm running water from the hydrant at my barn. The line to the hydrant is Tee'd in to the main house line right at the well. The pressure tank is in the house. So when the spigot is used, water flows backward though the main line from the house, until the bladder tank kicks the pump on. My worry is that the pump is having to reverse the direction of the water flow in the main line when this happens, potentially causing a larger inrush current to start the pump. The water lines are 1-1/4" and the main line from the well to the house is 200', so that's a lot of water to change flow direction on. Could this be why it's tripping? Are there solutions for it? I can draw a diagram if that helps explain the layout better.
Thanks!!
Thanks!!
