Blue Oaks
Guys,
As mentioned in my other thread, I may be bidding on the property next door in January 2023. The owner owes back taxes and the county is going to auction it off. No buildings are on the property, but there's a power line down to maybe a breaker panel.
Property details: It's approx 4 acres, with about 150 feet along the road, and something like 1100 feet up and over a steep hill (full of poison oak).
What I'm thinking: I'd buy the property at auction, drill a well down by the street where all the other homes along the road have their wells. I'd have my friend who's a Bobcat master cut a large, level pad approx 100-140 vertical feet above the well for water tanks. I'd ideally put QTY=3, 5000 GAL tanks on the pad. I'd trench straight down the hill from the pad to the well for a water supply line up, and a much larger water line down. I think my neighbor on the other side has essentially the same setup- the county requires a LOT of water volume if I were to build a house or ADU on the property, and I'd like to do it only once. I *think* the pipe is 5" coming down, and his is galvanized. Not a trivial expense, but again it's always best to do it right/best the first time.
Bonus: I'd trench over from the new tanks to my existing tanks I moved up the hill a year and a half ago. My well produces very little water this time of year, and being able to open a ball valve and replenish my tanks in short order is very appealing to me.
Details: Since it'd be a ground up design, I'd like to run power up to the tanks in addition to the float switch. The run would be quite long, maybe 400 feet of wiring? Would it be best to run a 240V set of wires, and have a small shed up there with a breaker panel to step is down to 120V for things like a wi-fi water level gauge, etc? I likely won't be able to see the tanks from the house like I can my current ones, so a remote monitoring system would be ideal.
Known Unknowns: Well controller, mostly. I think my well guy will have a solid recommendation. Well pump will have to pump water up the 400-500 feet to ground level, then an additional 100-140 feet to the well. I'm sure the well guy will have a recommendation here.
Input solicited: In addition to the question regarding running power to the top, what else are "nice to haves" and any other "need to haves" that I'm missing? Like I stated, I'd like to do it right the first time.
Andy in Morgan Hill
Andy in Morgan Hill
