Retention Tank Options
ChrisCCCC
British Columbia
Hello.
I am wanting to install a water retention tank as an emergency water supply on my well system. If my pump fails, I can drain the potable water from the tank directly. Wanting to integrate the tank to the end of my treatment system, and flows into the house to ensure the water in the tank constantly gets replaced, and not stagnant. Attached an image for reference.
Looking at a tank like this:
Does this plan make sense? . Thank you in advance.
JoeJee
HVAC Contractor
Arkansas
I am not a plumber but I think that is a viable option as long as it is potable. Need a vacuum breaker. Your emergency water source line needs to be very short. Like 6” or less.
ChrisCCCC
British Columbia
Thanks for the feedback. Planning to include a vacuum breaker, and the water in the tank would all be potable.
Why does the emergency line need to be under 6" long? Would a longer line cause too much resistance when I'm draining it by gravity?
Consider running some water out occasionally. There may be sediment, and your big tank is doing double duty collecting that..
Also, that should also take the dead-end / stagnant-water problem that I expect that JoeJee is concerned with.
If the pump dies, and you actually are drawing emergency water, you will want to open a valve/spigot connected to the output of the big tank. That will admit air.
ChrisCCCC
British Columbia
Thank you for the help.
