Resurrecting on old well
MedicMJC
Waterford, NY
I'm looking for words of wisdom for a fun project resurrecting an old well. Maybe this will help others along the way.
Here's the background: We recently bought a 100 year old house that has a well adjacent to it, however, it now has "city water". We bought it from someone who renovated it, including repairs to the basement walls. Everything related to the pump inside the basement is gone; no incoming pipe, no pump controller or wiring, etc. There is a small decorative pond on the property with a little waterfall that constantly needs refilling. Therefore I though I would try to resurrect the old well to use for the pond and other outdoor irrigation rather than use domestic water. In other words; I'm in no hurry, it's a low budget project and ultimately success is not mandatory! There's no data plate that I can find, so I have no idea how deep, when it was put in, if it even has water or anything else.
I'm not a plumber, but I have had to replace a couple of well pumps in my time. This one has already caused some grief. Thanks to this post: https://terrylove.com/forums/index.php?threads/odd-pitless-adapter-help-needed.65228/
I was able to figure out what I was looking at, I think.
I need to dig up the outlet pipe, I am sure it's cut between the house and the well since it no longer goes through the new basement wall. Unless I abandon the project I would need to drill through the wall and put in pressure tank and wiring.
Since I have no idea about the pump, pulling that is probably a must. I can make an unsafe assumption that it's a three wire with a start, run and common but no ground. Once I get the outlet pipe exposed, I may get a controller and make a temporary connection to see if water comes out. Which leads to my first question: 120V or 240V? I don't have enough experience to guess or know which was more common.
If I must pull the pump. I have a tripod and enough equipment to pull it, provided I can get the pitless adapter apart. I need to loosen that wedge, and it is 5' down (NY has 48" frost line) so I'm thinking a length of 3/4" iron pipe and pound one end into a square. I know others have had success with a modified curb key but a 60" key would barely reach that nut. I also read someone welded a 1/2" drive socket backwards onto a pipe, but I don't trust my welding skills that much.
Feel free to comment and/or advise!
You don't necessarily need a pressure tank or pressure switch for your decorative pond or irrigation. Just turn the power on and off.
For welding, have somebody else do it. Your local non-chain muffler shop may have somebody who does TIG welding.
Look in the breaker box for a label and/or breaker that clues you into the 240/120 volt thing.
