duckyjp
Well I had the nightmare scenario of a bottom basket rupturing and sending resin throughout my plumbing system. After doing some research, I learned that a fine mesh bottom basket is much less prone to rupture so I replaced the old standard basket that came with the unit (Kenmore 350 series) with a fine mesh one (Fine Mesh 11 Segment 1.05" Bottom Screen for Water Filter & Softener Riser Tubes SKU: FM-105-11WDF)
Problem solved - or so I thought. Now I am experiencing low water flow throughout the house (which makes sense to me - I suppose I added a bottleneck to the system). When I bypass the unit, water flows the way it used to.
My question is this: is there a high flow bottom basket that isn’t as prone to rupture as the original part or am I stuck with the lower flow water situation?
A related issue: after I made the basket switch I noticed that after a regen cycle, super salty, foamy water comes out for about 5-15 minutes. Could this be related to the basket change and is there a way to mitigate this?
