Hi All,
Looking at replacing the cast drainpipe under the basement slab sometime in the next year or so... Are there any special considerations when handling the excavation/replacement of the portion of the drain line that passes under the block foundation wall, and leads outside to the septic tank?
The block foundation sits on top of a concrete footing. Would it be proper to excavate an 18" wide trench underneath the footer/block wall in order to remove/replace the cast drainpipe? Or is some kind of special support needed for the wall/footer?
Maybe I'm overthinking it, but it's the one aspect of the job that seems pretty critical to understand...from a structural standpoint.
Thanks for any insight.
