Hi guys I’m new to the forum and new to owning a well. I bought some property with a well on it and has been fine for the year I’ve owned it now all the sudden I don’t have as much flow as I used to and very little pressure. Before if I turned on the cold water in the shop slop sink it would shoot out and make a huge mess now it just flows out like a garden hose with no nozzle on it. I think my pressure tank may be bad. It feels like it is really full with water. The tank is a wellmate wm-6 which is a bladder style tank from what I’ve read. One question I have is if the tank was bad and water has mad its way into the bladder when I push the Schaefer valve at the top wouldnt I get water instead of air? It still shows 30lb on my when I pressure test it. I did shut the power off to pump and I opened the faucet at the lowest point and drained the system out. Once it drained to zero on the guage by the pressure switch I rechecked the pressure in the tank and it then read zero and I put some air into the tank and it shot more water out of the faucet. When I bought this place there was also another pressure tank just sitting in one of the corners this one is huge it’s a wellmate wm25-wb. This one obvious is not hooked up to anything and I checked the pressure on this tank and it reads 40 psi. So I would assume this tank is good except when lay it on its side I can hear liquid sloshing around inside of it, not a lot but definitely some liquid. I’m having trouble wrapping my head around this because of the bladder in the large unused tank was damaged it wouldn’t hold air correct? Atleast not 40 psi. But if the bladder wasn’t damaged where is the liquid being held and why would it not just drain out when stood upright?? Any ideas or suggestions would be appreciated. I’m sorry for such a long post but I have read a lot on pressure tanks and I haven’t quite come across a post that is related enough to my situation that has sufficiently been able to answer my questions. Thanks again
