AZ_Sunshine
Hello professional experts. I have a 2021 residential Bradford White 50-gal, nat’l gas hot water tank RG250T6N with a defective (pilot would not light) Honeywell gas valve WV8840A1057, with 4” WC regulator valve. My gas valve was replaced yesterday by a local plumber with a WV8840A210 with a 5” WC valve. Are there any safety concerns or potential to decrease the life of my tank with a 5” valve pumping roughly 20-25% more gas than the tank was built for? Compromised or damage to the tank or inside components and void Bradford White manufacturer warranty? Code violation?
Also, after replacement installation the plumber left with the cold-water valve off and the T&P valve open. My tank was dry-firing at a high setting (B) for 30 hours with a few inches of water in the bottom of the tank. I left my home to go out of town right after the plumber completed the replacement. Upon returning home, I wasn’t able to take a shower because none of the hot water valves produced any water (shower, tub, sink etc.). I checked the tank, green light flashing, heard the load burner going then noticed that the water valve was closed. I opened it and heard water gushing. I thought my tank was filling up. After 15 minutes I checked a hot water valve, still no water. I went to the garage, green flash, burner still running high, loud gushing water flooding the side of my house. I turned off the water and noticed the T&P valve was vertical. I have turned off both the gas and water to the tank until I get some advice, then I will contact the plumber.
I hope you can help me with the two questions. 1) Effects of dry-firing for 30-hours 2) is the plumber installed gas valve (WV8840A4210) rated at 5.0" WC safe to run when my Bradford White tank is rated for a 4.0" WC valve? Your professional input is valuable and so very appreciated.
