Michael P Reilly
Can someone please translate this for me? Haha.
My remodel which is starting small in a laundry room that I have brought up in other threads, will later on also be including the conversion of one bath(and bedroom) into two baths. I will need to completely redo all the DWV system. So I am researching the code to find all the nuances involved. I have read the above code about a dozen times and looked up all the definitions...and frankly I am still puzzled. Can someone put this in English...please?
P3005.5Connections to offsets and bases of stacks.
Horizontal branches shall connect to the bases of stacks at a point located not less than 10 times the diameter of the drainage stack downstream from the stack. Horizontal branches shall connect to horizontal stack offsets at a point located not less than 10 times the diameter of the drainage stack downstream from the upper stack.My remodel which is starting small in a laundry room that I have brought up in other threads, will later on also be including the conversion of one bath(and bedroom) into two baths. I will need to completely redo all the DWV system. So I am researching the code to find all the nuances involved. I have read the above code about a dozen times and looked up all the definitions...and frankly I am still puzzled. Can someone put this in English...please?
