WellOff
Replacing existing cvpvc in a manufactured home. The cvpvc is run _under_ the bottom of the floor joists via straight lines (parallel and perpendicular to the joists) with Tee'd lines feeding the various fixtures. I will be doing a trunk and branch topology using manifolds.
Is there any reason, other than aesthetics, that I can't run lines in the most direct fashion in order to reduce total pipe length (more so for performance than cost)?
