John, do you have links to anything specific in the trays? I know what all thread is, but I'm not sure the proper terminology to search for and "all thread pex tray" (or "support") returns a massive variety of options that don't look correct
EDIT: Sammies look to basically be a screw with a threaded nut so you can attach all thread or something similar into them. so they're just an anchor, correct?
Thanks to some additional research it seems that it's code in WA to insulate pipe in unconditioned crawlspaces, whereas previously I had understood it to just be recommended.
With this what I've decided to do is wrap all the pipe (still cant figure out if hot and cold needs to be insulated or just hot supply lines) in standard foam insulation and hang it in 1.5" PVC J-hooks (or 2" if those fit better). I'm on the fence about the J-hooks though because the pipe isn't "secured", it's just "sitting" in the hooks.
Questions from this:
- something like a talon captures the pipe versus a hook doesn't; is there concern or code reasons why a hook wouldnt be acceptable? What about something like a double-sided J-hook so that I can run hot and cold and only need to hang one hook for each support point?
- relating to the first bullet point, does pipe insulation have to be continuous? or could I use normal tubing mounts with a "break" in the insulation for the clips to be directly on the PEX
- is there a preferred pipe insulation? can i just go to lowes or HD and pick up the 6' sections that are split down one side to slide over pipe easily? unless it's needed I wasn't planning on getting the adhesive stuff
Edit: Tuttles I saw your response after I typed mine out, that double-sided J-hook is exactly what I'm referencing above with the double clip. The question about insulation still stands, if I use this double-sided hook sized for PEX can the insulation "break" at the hook?
