PEX-A installation
Coatesville, PA
So, I'm an old school DIYer. I've received great help here before. I bought a Ryan home a little over a year ago. All of the supply lines are PEX-A. I'm used to copper. What I've done in the past is tie into existing supply and putting in shutoffs so I can work downstream without shutting off the whole house for extended periods. Solder and you're done. It's a 10 minute job. What I findwith the PEX-A is the fittings leak. I've put in these stubs without having the water on for 2 hours. I shut the valves, turn on the water and fittings leak. My better half went to bed angry because we don't have water.
I'm afraid of connecting the rest and still having it water everywhere. How do you guys ensure the fittings don't leak?
PEX-A fittings leak? That is unusual. How about a photo of a leaking fitting... close but not super close. Show some pipe too.
I had a Uponor pex-A fittings leak for a time, but I attribute that to my technique. I can describe my malfunction, but that is not important. I put a worm gear clamp around the expansion ring, and the leak stopped. I was later able to remove that worm gear clamp without leaking.
Also, what markings are on the pipe?
Coatesville, PA
This Tee leaked. Here is the pipe as requested.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I cannot speak to your pex A problem. I am a certified Uponor PEX installer. We only use same-brand complete system parts.
If we ever had an issue with UPONOR fittings, we would immediately call the rep and get someone on the case.
Contact your supplier or rep.
How old is the house? Still under warranty by chance?
JoeJee
HVAC Contractor
Arkansas
What does that have to do with the work that I’m doing?
A response like that is a good way to keep people from helping you.
Age of home and if it is under warranty or not will help guide those who are willing to answer you.
Coatesville, PA
My apologies if that came across poorly. I’m not asking about work done by the builder. I’m asking about work that I am doing. I m sorry if I don’t see the applicability of age/warranty on my modifications.
You seemed to be concerned about a leaking PEX tee. That may not be part of what your immediate concern is.
Are you asking how to tie into PEX with PEX, or how to tie in to PEX to run to a copper stubout?
Coatesville, PA
You seemed to be asking about a leaking PEX tee.
What are you asking?
I am asking about fittings that I installed.
From my OP “
I've put in these stubs without having the water on for 2 hours. I shut the valves, turn on the water and fittings leak…
How do you guys ensure the fittings don't leak?”
Can't see what you are pointing to. What stubs? URL?
How did you connect? Clamp, copper rings, expansion rings after using an expander tool as in your photos?
wwhitney
Berkeley, CA
The OP cut in the tee in the picture in photo 3, and it is leaking.
How about a photo where the camera is pointed perpendicular to the plane of the tee? Were all of your cuts on the PEX square? Are the expansions rings fully seated on the end of the pipe? Are the expansion rings all touching the stops on the tee?
Cheers, Wayne
Oh.... why was he talking about the builder and the stubs, and making the general statement rather than saying that the tee that he put in leaks? Is that because there are two more leaks for the stubs he put in?
In that case, are we sure he used F1960 expansion fittings rather than "PEX" fittings?
Did he twice expand the same pipe?
wwhitney
Berkeley, CA
My experience with different PEX fittings is limited, but doesn't the little black tab visible against the expansion ring mean it's an F1960 fitting?
Cheers, Wayne
I was wondering about that. I have only used F1960. I used a hand tool. My only leaks were when I expanded twice due to the ring sliding onto the pipe in my first attempt due to wet a wet pipe. I worked around that with a worm gear clamp around the ring, but later I removed the clamp, and no leak.
Coatesville, PA
Cheers, Wayne
Yes. Yes. And yes.
Coatesville, PA
I talked about the builder because you brought up age of the home and warranty. Again, as a DIYer, I do this work over a couple of days. I can’t turn off the supply to the whole house during that time. I stub in a valve in each cold and hot supply so I can work downstream without having the water off.
I guess I put in too much background information. Back to my original question:
