Outdoor spigot leaking
EJMVS
Illinois
Hi,
I have an outdoor spigot that leaks from between the packing nut and the valve stem when the water is turned on. I tried removing as much of the existing packing material as I could, then wrapping some new teflon rope around the stem 3 times. Unfortunately, it only made the problem worse. Should I use something else for packing, or should I just use more wraps of teflon rope? Attached are photos of the spigot and of the internals (before removing the packing).
more packing, less packing clean stem good tighten nut tighter . just gotta experiment a bit
