New Cabin Build Plumbing Plan Aframe House
Dummer Plummer
texas
any and all advice appreciated
No code inspection cabin
But I will follow/ meet if possible
Aframe house with open loft above bath and kitchen
Venting should be through leaning wall only
Have unlimited crawl space access
House sits on high stilts
Have some overhead hidden in ceiling possibility over bathroom area
Shower/ W/D wall shared with kitchen
Plan to vent dryer through floor
Stack Mini washer and dryer
Shower supply in wall between W/D stack wall and shower
Opposite wall is vanity and commode
This is an outside flat wall
Mechanical access area could hold tankless LP hot water
Kitchen sink DW and venting for water heater necessary
No water lines to refrigerator necessary
Have basic knowledge and understanding of installation
The PLAN for supply, outflow and venting has me lost
Thanks in advance to all
Pay for rough plan! or volunteer plan? Contact me! Thanks so much
Tuttles Revenge
Where is your septic in relation to the building?
Waste and venting is the hard part. Water supply is super easy, but depending on location may want to be able to freeze proof everything.
Dummer Plummer
texas
Thanks so much for your reply
I think I understand supply
Drain and vent is a difficult situation
Main drain to septic would follow green arrow
Red dots are drain locations
Underside of house will be spray foam insulated
Heat tape or similar could also be used
Water cutoff for extreme weather is possible
Freezing shouldn’t be a problem
Thanks for all suggestions!
Tuttles Revenge
Perfect for horizontal wet venting the bathroom. The sink drain will become the vertical dry vent for the bathroom group of fixtures.
Downstream of the bathroom group you would tie in the laundry and the kitchen. Each of those will have their own individual traps and vents for those traps that rise vertically.
Dummer Plummer
texas
Thanks so much!
first, I apologize for my childish drawings
Secondly, I have probably made a terrible mistake by not seeking advice and opinion before I planned layout for bathroom
In this space, with the fixtures and sloped wall, this was the only configuration I could come up with :(
Flat gable end of the A-frame has a door downstairs, double upstairs and a window above
Stacks of headers and structure
I can drill down inside this wall but not up beyond ceiling
The bathroom vanity and wc sit on this wall
maybe I could do a long run up/ horizontally to sloped wall then up and out
Could be too close to window?
Washer dryer back to refrigerator at the kitchen wall
Could I have been vent or washer, dryer, horizontally, and up and exit with vent hood exhaust (on sloped wall)?
There is an open loft above all kitchen and bath
bathroom will have sheet rock ceiling creating some space between it and loft floor
Ceiling above kitchen area is the underside of loft floor
There are no walls in the loft above
a vent pipe for washer and dryer, would be running up through the middle of a “room”
Stacked mini washer and dryer will have a closet to ceiling and be hidden
Same question with bathroom sink could I go up wall then across horizontally through ceiling space and exit window
Is it possible for washer, dryer and WC vanity sink vent to join a main stack through sloped roof?
All my venting options must be through the sloped side roof
There is a window above the kitchen sink and one between shower and WC on the sloped wall/ roof
I hope someone can make sense of my explanations. maybe along with my drawing, and my first post description above?
Thanks so very much for your help in fixing my confusion!
Dummer Plummer
texas
Thanks so much!
Dear Tuttle
Here are some photos to help explain the situation
I learned the editing markup on my phone :)
Sorry it still looks childlike!
For the bathroom I have found a few small places to sneak vent pipe out to sloped side of house
House is cabin, in woods and has no requirement to meet code, but I would like to do it as “right” as possible.
Functionality is more important to me than rules or cosmetics. I do want the vent to vent
If necessary to create a soffit or have an exposed ductwork vent pipe, I can work with that.
Green line on picture is venting possibility?
The other side of washer/dryer/shower wall is kitchen.
Backing to shower portion of wall is LP gas cooktop (supply and vent) and cooking exhaust vent. And next to cooktop, a LP tankless hot water means another vent! This water heater will sit in the corner, and I believe will vent out the sloped wall without problem.
Kitchen sink and dishwasher are no problem as they sit on sloped wall without any obstacles between them and roof
The third photo is the outside wall of the bathroom. Could the vent come through the wall and then pipe up through the roof on the outside?
Thanks so much for your ideas!
Tuttles Revenge
I don't think I understand why the initial layout of the drains won't work. Its the simplest way to install them with the least number of vents from fixtures. And honestly the laundry could have an AAV for a vent and work fine so long as theres a vent out through the roof from the bathroom and kitchen combined or separately. Vents can offset horizontally through walls and ceiling spaces to get where they need to.
Dummer Plummer
texas
Dear Mr. Tuttle,
Thank you for you patience and help.
You are truly appreciated.
I think I am the one that doesn’t understand the layout you planned for me.
The sink drain vertical vent works for horizontal wet vent on shower and WC. Yes?
Where does the plan have the vent pipe for the sink exit the house?
W/D are horizontal wet vent to vertical kitchen sink? With one exit through roof. Yes?
Thanks so much!
Sorry I am
Completely clueless :)
Tuttles Revenge
In the layout I drew over your plan view the Bathroom fixtures are combined into one single Horizontal Wet Vent system where the top half of the horizontal pipe is the vent for all of those fixtures. The sink rises vertical into the wall, to the trap arm of the sink, that portion is the wet vent. Above that trap arm is the dry vent that continues through the roof in whatever manner it can or needs to as long as it only goes horizontal or up with no down sections that will trap water and negate its purpose of venting. This method reduces the number of vents from 3 to 1 single
Downstream of the bathroom group, you will branch off for the laundry. The trap is generally above the floor with a stand pipe that rises up about 30" for the hose. That trap requires a vent. The vent again can travel up and horizontal to other vents, or through the roof. Up and Horizontal only, no down.
Ditto with the kitchen sink as the laundry. The dishwasher just connects to the sink trap via a hose, so we don't really consider it in the drain plan.
Dummer Plummer
texas
Thank you so much! Single exit!
I will get that sink vent out the side roof!
Gable (flat) ends of the house being all glass and doors, and 2 other sides of the house being sloped wall/roof, structure has gotten in the way of necessities for luxuries
Thank you again!
