Need help locating a sink bowl
Gagecalman
Active Member
Baltimore, MD
I'm trying to help a friend with a cracked sink bowl.
I believe it was bought at Home Depot years ago.
The opening is only 48" so the 49" granite top was installed in the rough opening before the drywall. Trying not to have to gut the walls.
I was wondering if I could find a replacement sink bowl and replace the cracked one.
This one has a unique shape.
Thanks for looking and any help would be appreciated!
I see you have the spec's for the Caxton. It does look to have a different shape to it though.
What are the dimensions on the bowl you have? An any information on the cabinet brand to see if that bowl can be backtracked?
Gagecalman
Active Member
Baltimore, MD
Hi Terry,
Thanks for the quick reply.
Yea the Caxton doesn't look right.
The opening in the top is 17-7/8” wide by 12-3/4” deep.
I looked on HD's site and the name Halstead Products comes up to answer some of the questions.
I googled it and they sell flooring. Maybe not in the sink business anymore. I sent them an email anyway.
This is a drawing I found on HD. A little skinnier but the shape doesn't look right.
  • Rogers vanity top Halstead.pdf
Tuttles Revenge
I didn't see anything with that same flat back area. All the ovals are very round across the back. The only similar I see are oval Overmounts.. But not sure that those would be big enuf to undermount in the same hole.
May need to see if replacing the entire top is More or Less than having someone cut a new oval shape.
