NavienCirc Recirculation valve question
Freedomeagle
Virginia
Have a new home with a Navien Tankless LGP hot water heater. The house is approximately 100 ft long with an ensuite at one end of the home and the master bath at the other end. The Navien sits about 30' from the ensuite end. I want to put a Navien Recirc valve in so I can get hot water faster at the kitchen, master bath, and ensuite. One of the local plumbers suggested two, one at each end of the house. But, the way I understand the valve works, with two, it seems one would be in conflict with the other. Can you run two recirc valves on the same system or just one? If one, where should we put it. The kitchen and laundry room areas are the ones who need the quickest "on demand" hot water, followed by the master bath and ensuite area.
