Grid power has no problem with across the line starts. Soft starts can reduce the size of generator or inverter needed when the grid is not being used. Standard across the line starts are no problem for the pump system as long as it doesn't do that over and over and over. Cycling causes about 90% of all pump problems, and this is just one of many that the Cycle Stop Valve solves.Thanks for laying all that out Valveman. Do you consider the fact that the SQ has soft start built in a significant advantage? I can't find any other pumps that have soft start built in. It looks like you can add an external soft start box to other pumps but then you're looking at another $350-$450 plus the cost of fittings added to the cost of say a good Franklin pump. Also it seems the external soft start limits the initial starting current to 40-50% of what it would be, whereas the SQ seems to ramp up slowly and with almost NO extra amperage drawn at all? That seems like it's worth the cost of admission in and of itself? It seems like there would be a whole lot less wriggling around going on down there from start ups?
I may also be naively thinking that the 3" diameter is actually a plus when it comes to all the worries about things possibly getting stuck?
The soft start in the SQ takes about 5 seconds for the pump to get up to speed. The tank must continue to supply water until the pump gets up to speed. The amp draw for this 5 seconds is usually about 150% of running amps. 5 amp motor starts with 8 amps as compared to 30 amps across the line. However, there are two components to a soft start. Amplitude and duration both play a part. Amplitude of 150% is very low, but 5 seconds for starting is very long. The SQ can do that because it is oil lubricated with ball bearings. But every component in a pump and motor has a mechanical or resonance frequency. Slowly going from zero to full RPM will go through the mechanical frequencies of every component in the pump and motor. At a certain RPM the shaft will vibrate. At a different speed the balls in the bearings will be affected, and so on. The components in an SQ pump are just so small the vibration is of little importance, but is does happen. Some people think having an oil lubricated motor in the well water can be a problem. While the SQ may have a few problem, I think it is probably the best you can do when running on a generator of invertor.
But there are advantages to 4" pumps when running grid power and using a Cycle Stop Valve to eliminate cycling. KIngsbury thrust bearings are completely frictionless when running. But the film of water that hydroplanes between the bearing surfaces is not present until the motor gets up to at least 50% of full speed. Every start wears on a Kingsbury thrust bearing. The longer it takes to start, the more damage to the bearing. At least 50% of full speed needs to be achieved in less than 1 second to prevent damage. This can be a problem when used with a soft starter. It is best not to soft start a Kingbury thrust bearing.
While a Cycle Stop Valve can do little about the amplitude of the current on start up, it can great reduce duration. Starting against an almost closed valve can greatly shorten the duration in time it takes to get to full speed. Pumps like to run, it is the number of starts that shortens their life and slow starts can make it worse.
I have a 4" pump in a well for stock water that hasn't shut of since 1996. Limit the cycling and 4" pumps will last longer than any ball bearing pump/motor.
