Lead Stub Out - fixable?
gpstew
St. Louis 63109
Hello all! I'm brand new to the forum and a DIYer (at best). The best/closest info I could find on the web regarding a situation like mine was from y'all's forum - thanks.
Info - location St. Louis
House build date 1936 - plumbing update - unknown
I went to put in a new vanity/sink and when I took off the connector for the stub out, the copper(?) inner sleeve deteriorated. The sink is an IKEA one, so the plumbing was a bit different sizing (hence taking off the adapter).
Questions -
1. Can anyone confirm what I am looking at? Is it a lead stub out with a clumsy lead flange and a copper 1 1/4 inner sleeve that is soldered in?
2. Would I be able to (is it possible/the preferred method) desolder and then resolder a new copper fitting so that I have something to attach to?
3. Is it a wall tear-out situation? Unfortunately, the "other side" is our stairwell and plaster walls.
What is the preferred method moving forward?
All help is appreciated! If more info is needed, let me know and I will do my best.
The drain line could be cast iron with a copper sleeve 'leaded' in. If you take a magnet, does it stick to the outside of what you can access? If so, you should be able to remove the lead from the bell of the end of the cast iron and then use a donut to copper or pvc drain pipe. https://www.fernco.com/plumbing/donuts-o-rings/donuts
Hello all,
I wanted to give an update to anyone who happened to be curious.
After I described the situation to a couple of people and realized I was going to have to bust tile, I ended up having a plumber come out. I got a recommendation from a friend and was very pleased with the service that I received. He even went so far as to "not allow" me to use my previous pipe system - he was not a fan of the flexible accordion piping and he provided a solution at no extra charge.
All said and done, the flange had to be cut off and a Band Seal coupling was attached. However, the first try did not take, as there was not enough lead pipe to attach to - therefore, he came back the next day and cut back further and was able to successfully attach the coupling.
Works like a charm. All said and done, it ran me $100 total (parts and labor).
Problem with banding onto lead pipe, if that is what we see above, is that the lead will collapse from the pressure of the band. We insert a brass sleeve to compress against IF I ever have to connect to lead. Problem with that is most lead is so deteriorated that it rips apart. I generally avoid it by removing all the lead and getting back to a solid drain.
Lead is a PITA IMO.
Lead is amazing and far from being a PITA
It is acid and most chemical proof, has the mass to be quiet and has amazing longevity and easy to work with considering how long it can last
I was called to replace a 6" copper box roof drain on a building that was built in the late 1800's
We had no access below as someone had installed mirror ceilings around 1930
We we removed the copper box we were shocked seeing a 6" lead pipe, up to then the largest lead pipe I ever seen was 5"
With the roof open and seeing a 6" lead pipe and looking down I measured the lead pipe and it was almost 4 feet long
We just stood there thinking now what
We went to the nearest plumbing supply pick up a 4ft x 4 ft x 4 PSF sheet and lead 6 bars of solder 40 -60 I had a wiping cloth in my tool box
After cleaning the existing lead pipe we placed the sheet lead over the sheet cut a hole so the pipe would fit inside the lead and flaring the pipe over the lead sheet I was able to lead wipe the pipe to the sheet
The preparation took a lot longer than the actual lead work
One never know when the "old school" training will come in handy
