Laundry box no hammer arrestors
Plumber69
Prince Rupert, British Columbia
Got called on having no hammer arrestors on a laundry box. I know they make hose adapter ones for this situation, does it look bad? Or just change out the whole box with built in ones? Drywall going up soon
Breplum
Licensed plumbing contractor
San Francisco Bay Area
The add on WM arrestors are fine
wwhitney
Berkeley, CA
FYI, from the 2018 British Columbia Plumbing Code:
2.6.1.9. Water Hammer
1) Provision shall be made to protect the water distribution system from the adverse effects of water hammer. (See Note A-2.6.1.9.(1).)
A-2.6.1.9.(1) Water Hammer Prevention. Water hammer is a buildup of pressure in a length of horizontal or vertical pipe that occurs when a valve or faucet is closed suddenly. The longer the pipe and the greater the water velocity, the greater the pressure exerted on the pipe, which can be many times the normal static water pressure and be sufficient to damage the piping system. Since air chambers made from a piece of vertical pipe do not provide acceptable protection, pre-manufactured water hammer arresters are required to address this potential problem. Water hammer arresters need not be installed at every valve or faucet, nor in every piping system.
Cheers, Wayne
I don't find add on arrestors offensive, just put them on or ask client if they mind them
