The submersible pump connects to PEX (5106 160psi @73), which connects to the main PVC line (all inside the spring house). I am not concerned about the PVC, just the PEX. The switch is set to 40/60. See fittings in photos.
With a CSV installed, how well will the PEX and its fittings be able to withstand the increased back pressure during and after the slow 1gpm filling of the pressure tank?
The pump is:
SHUR-DRI
SD-A202-02
3/4HP, 10GPM 2 WIRE
230V 60Hz 1PH
Code: 001J09H
I have not been able to find a pump chart for this pump, but I did find one (https://assets.unilogcorp.com/187/ITEM/DOC/STAR_WATER_SYSTEMS_100304387_Catalog.pdf) that rates a similar pump at 162psi max pressure. Again, the PEX is rated at 160psi.
I am not sure how to estimate the "static water level." The pump sits in <2 feet of water, and the water line rises upward about 24 feet before leveling off.
Sorry if I asked about this before, but I did not have as much data.
The pump is:
SHUR-DRI
SD-A202-02
3/4HP, 10GPM 2 WIRE
230V 60Hz 1PH
Code: 001J09H
