How to fish a 1" pipe out of a 2" well
racer765
Michigan
Hello everyone,
I bought an old homestead that had burned down with a 2" well with a right angle jet pump adapter that hasn't been used in a very long time. I hooked up a jet pump and pressure tank, primed the system and I had a crazy amount of suction but no flow. Thinking the point was plugged I attempted to pull out 1 1/4" well pipe that was inside of the 2" pipe. It was very tight at first then went concerning very easy. I pulled out a 20 ft straight section of 1 1/4 with a bell reducer and a 6" stub of 1" pipe. Using fiberglass chimney sweep sticks I was able to feel something solid still in the well at about 26 ft. Endoscope revealed it's a longer section of 1" pipe (possibly pulled the threads out of a union explaining the full threaded 6" nipple?). Water level appears to be approximately 27'. I'm not sure how to remove the broken off pipe or could I drive it down into the well? All of the extractors I've seen online go through much larger diameter pipe than the 2" pipe I'm working with. Thank you.
Hello everyone,
Have you resolved this issue?
Hello everyone,
Sorry for your problem. Done lots of fishing but that would be a tough one. Maybe a large concrete anchor bolt that fits snugly in the 1" pipe. Push it in and something will break if the pipe doesn't come loose.
