Cai24
I ordered a custom shower pan from Tile Redi, and I had selected the compression drain option. I felt like this would be easier for me, because I don't have access from below. The standard pans are solvent weld, and while it's doable, I would have to get the thinset down, place the pan at the correct spot, and make the drain connection properly within a short time window. I'm worried about messing up and not getting it right.
I went to dry fit the pan yesterday, and now I'm thinking that they used the wrong drain. I realized that there is a stop halfway through. I've seen YouTube videos where people have this drain (Tile Redi refers to it as the wonder drain option). Some installers had a high PVC riser, they set the pan over the pipe, and then cut it to height with an internal pipe cutter. From there, they install the gasket and locking nut. There is also no threading on the inside of mine, but the bottom (under the pan) has threading. Is this possibly a solvent weld version, am I missing a part, or is it a different drain type entirely?
I appreciate any help!
