Ed95Pont
I am a long time lurker that could use help choosing a well pump. I just closed on a new retirement house under construction that I will be finishing. The well is dug with no pump.
The home is 1700 sqft 2 total bathrooms 3 bedroom 1 bathroom on second floor. No plan for sprinkler. May add a garage with bathroom
Cycle stop valve will be used
The well is 150' deep Static at 40' GPM estimated 4 gpm bailing method ?? (Did they even measure GPM ?) See attached driller report.
If the well ends up low yield I think the pump should be set as deep as practical
20 feet head 100 foot to house softener (if needed) ect.
140 feet head for 60 psi
140 feet head for pump depth worst case
Which pump would you go with
SE 10sq07-200 Should be fine but may not pump if the well is low
Se 10sq07-240 Should be fine but may over pump if the well is low
Thanks in advance
Thanks in advance
