Finding my well.
Tom E
Byram twp. NJ
I bought my house in 1984. The house was built in 1970. The well is shared with the house next door and we both have our own in home jet pumps. I never knew exactly where the well was and it doesn't have an above ground cap. The neighbor is in a nursing home and no one lives there right now so I can't ask him if he knows. There is no problem right now except that I am in the process of replacing my 44 year old jet pump. Because of the age of the well I would like to find out where it is just in case. How can I go about doing this?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Metal pipes can be traced back with a metal detector. Plastic pipe you may need to feed a wire through to find with a detector, or just start digging. :)
Greenmonster123
Active Member
Sag Harbor, New York
When I need to trace plastic pipes I use a 200’ wire snake and a wire locator. Regular metal detectors won’t work if it is deep. You can probably rent a locator from electrical supply house or irrigation supply house. Also if you think it is a steel casing a Ferro-magnetic locator works very well for finding metal objects buried vertically
Toolaholic
General Contractor Carpenter
Marin Co. Ca.
Find out who has lived in your hood for a long time and is somewhat Mechanical. They may remember the well driller Co. then call them.
https://terrylove.com/forums/index.php?threads/fleck-5600-twin-1054-tanks-and-chlorine-injection-valve-leak-media-replace.82624/page-2#post-595812 says
NJ attempted to digitize well records. you can search various ways here:
https://www13.state.nj.us/DataMiner...ategory=y&catName=Water+Supply+and+Geoscience
can search by well driller, when well was drilled, location of well,etc. my well was drilled at about the same time and I was able to locate the record (I think) based on the location with no other records being close in proximity and the timeframe being correct​
If you cannot find the info yourself, https://www.state.nj.us/dep/watersupply/pw_permit.html has links where they offer to search for $10.
Dana
In the trades
Can't make it work for me. But I have dug where I was told and some people can do that very well.
Every time I've tried it with bent wires I ended up finding the power lines instead (usually over my head, not exactly where I was looking. :) )
