Filter and UV sterilizer maintenance schedule
ivanivan
New York
My house has well water running through a sediment prefilter and UV sterilizer, and I'm looking for guidance on how to sequence the filter/sterilizer maintenance.
Setup
  • Source: private well, depth 100 ft
  • Whole-house sediment prefilter: Culligan P5A, 5-micron spun polypropylene, 2.5" x 9.75" standard housing. Rated 2 months or 8,000 gallons
  • UV sterilizer downstream: HQUA-TWS-12, rated 12 GPM, 9,000 hr lamp
  • Household: one person, estimated ~60 gal/day
Maintenance
Given my usage, I think I could reasonably replace the filter cartridge 3 times per year.
The UV system requires a new bulb once per year, and I'll swap in a clean quartz sleeve at the same time.
Scheduling
I want to be prepared for high turbidity times of year (e.g. spring snowmelt). I'd also like to avoid maintenance during the cold winter months, if possible.
I'm considering replacing the filter cartridge every March, July, and October.
I'm less certain about what time of year to do the UV maintenance. A couple options I could think of:
  • March: fresh lamp and clean sleeve entering the dirtiest season; downside is the year's worst deposits sit on the sleeve for the rest of the year.
  • May: fresh lamp and clean sleeve right after dirtiest period; downside is the lamp and sleeve would be less effective going into the dirtiest period.
I suspect March is the better choice for UV maintenance, but I'm curious for other thoughts.
Thanks in advance.
1. You have a pressure gauge at the pressure tank. The Culligan P5A is after the pressure tank. A pressure gauge after the filter would let you check the pressure drop when you flow the water at a rate you can control. That could serve as a good indicator as to how clogged the filter element is.
2. A 2.5 x 10 cartridge is not so large. A 4 x 20 cartridge would pass more water before clogging. The cartridge would have over 5x the volume. Maybe you could add one of those before the Culligan P5A to take load off of the current cartridge. When changing a cartridge, always have a replacement O-ring on hand, because sometimes you cannot reuse the old one.
3. IMO, most deep wells don't need UV. I think that a lot of positive coliform tests are false positives due to inadequate sampling technique. I am not a pro. Sanitizing your well and plumbing could knock down bacteria for a while. Also, after getting your UV working, you should have sanitized the plumbing after the UV, including the hot water heater and piping.
