Shaggy76078
Been running through relief valves on our 50 gallon a&o smith water heater. When we got this one it was recommended to add an expansion tank. Did that. Went through another pressure valve just 2 days ago. After hooking up my pressure gauge to a faucet, shows 120-130 psi coming from the road, expansion tank says max 80psi. I know ive read that the expansion tank psi should equal incoming pressure. Do i need a bigger, higher pressure expansion tank, do i need to lower the pressure on the shut off at the rd to 70-80 psi, do i need a prv at the water heater? Not sure where to go next on this as ive always done water heater replacements and never had an expansion tank added on ever.
