Drain snaked for 20+ feet, still backs up with a few cups of water
j thomas
Springfield, Virginia
You should not be able to see the flow of water from the roof if the bladder is headed down the drain line. The bladder should puff up, and the water should be flowing down. So nothing to see from above. If you are only putting the drain bladder into the trap adapter, that will not be able to pressurize the clog, and it will not be able to direct the vibrating stream to the clog. If you are unable to turn the corner down, how about inserting the drain bladder through the roof vent, and continue it down past the sanitary tee.
I used the bladder at the pipes entrance into the wall, not in trap(not easy to do with elbow so close). Only water running when I checked the roof vent was in the drain that is having issues.
Timothy Dean
McDonough
one more question, is there any major risk in using the bladder? my main concern is to also clog the shower and toilet, which are currently working fine.
I'm having the same exact problem!.
I swear it's frustrating. Jtk
Sometimes there will be hair on the stopper.
And then I push some paper through,, (with the p-trap removed) to clear out the toothpaste goo.
Just checking: if your lavatory sits overnight or longer, and you pour a quart/liter of water down the drain, the water will not go down. Right?
kevreh
Virginia
If there’s other fixture on the same run before where the clog is, could the bladder water just shoot up those fixtures drains? Wouldn’t you have to plug each fixture?
Probably. However with 1.5 inch pipe, the clog would have to be within 3 ft if a quart/liter of water is enough to cause the water to back up. Water could also squirt up the vent if the bladder is before the vent.
I
However the bladder also squirts a small stream of water straight ahead. That could produce a jet action in addition to the potential for pressure.
Andrew_4096
San Francisco Bay Area, California
Pardon chiming in at this late date, but I had a problem today with the double sink in my kitchen not draining and I think my experience might help someone in a similar situation.
It started when I tried to run several baskets of moldy strawberries and an old head of cauliflower through the disposal unit. The water backed up and there was zero drainage. I tried plunging it on the disposal side while pressing the strainer basket into the drain on the other side so as to develop pressure, to no avail. I removed the clean-out plug under the sink and ran a manual 8-foot long, 1/4-inch diameter snake through the drain line a couple of times, each time reinserting the plug and testing for drainage, but there was no improvement. Thinking I needed to snake ("rod") the line farther, I went to the store and purchased a 15-foot long, 1/4-inch diameter manual snake and ran it a couple of times, too, but there was no improvement. A visit to the crawlspace told me that the 8-foot snake was longer than necessary to reach the main sanitary line under the house. Flushing the toilet and running outside to peer down the main sewer clean-out confirmed that the main line was draining fine. I tried lye, spooning it into the sink clean-out with a long-handled bar spoon with the intent of maximizing the lye concentration closer to the clog, reinserting the plug, filling the sink drain with water and waiting a while; this didn't work. I then shot a measured amount of water into the clean-out under the sink with a Stream Machine water gun (600 milliliters), captured what came out of the clean-out and measured it, and it was the same volume that went in, to within a percentage point or two. By this time I'm sweating heavily (it's a hot August afternoon) and I'm getting very frustrated. This damn thing seemed hexed. After a cool-down rest I decided to try once again with the 8-foot snake, but this time I ran it in slowly, as if I were picking a lock, feeling the resistance inch by inch. Wherever there was resistance, I ran the snake forward and backward half a dozen times, as if using a file. Eventually, when I retracted the snake, the head pulled out a blob of what appeared to be fresh vegetable fiber (the cauliflower leaves) mixed with oil or grease. I reinserted the clean-out plug and ran a quick test with about a quart of water. It was draining now, so I filled the sink with hot water a couple of times to which I added some liquid dish detergent and let it drain. I also filled the side with the disposal unit with hot, soapy water, plugged the other drain with the strainer basket, then let it drain with the disposal motor running, acting as a low-efficiency turbo pump to boost the drain velocity and pressure.
In retrospect, it appears that the clog must have been a gooey, resilient mass that allowed the snake to easily pass through it, but then closed up again when the snake was withdrawn, much like a self-sealing automobile tire. The clog was eventually cleared by being persistent and using my sense of touch to feel where the clog might be, then working the area vigorously for an extended time.
A final note — I don't dump grease down my kitchen sink drain and I try to avoid putting any grease into the drain by wiping oily or greasy utensils, dishes, pots and pans with paper towels before washing them. I can barely remember the last time I had a clog in that sink — was it 10 years? 15 years? However, no matter how careful one is, even small amounts of oil will eventually accumulate on the pipe walls, acting as a magnet for plant fibers, hair, and so on.
