Connecting CTS Poly to IPS Poly
Rib
Halifax Virginia
As I was reading through some of the threads here I couldn't find the answer I was looking for, so since you all are much more familiar with this stuff I thought I would register and see if you could help. I am a retired home builder by trade, and only do simple plumbing projects.
So, I am in the process of building a barn on the property and have ran a 1" Black Poly Water Line down to it. It is 300' of ADS Poly Flex 1" CTS SDR 9 at 250 PSI. I ran the line to the closest underground line possible to connect to. I found it to be similar in size but the inside diameter is slightly different. After exposing several feet the existing poly is a Silver Line IPS SIDR, and my research seems to indicate that it is a 1" but different standard. Is there a way to connect the two using a barbed fitting, or other type of connection that will hold up under the pressure?
The CTS uses different fittings. 1 inch CTS poly is smaller than 1 inch SIDR. Ask the place you bought the water line from to recommend a fitting. You are likely to have NPT fittings in the middle. Maybe put a yard hydrant at the switchover point, and it can look like you planned it that way.
  • Like
Reactions: Rib
