Choosing the right system
kas435
Birmingham alabama
I need help making the right decision on the system for our home we just bought. The prior owner had very little filtration . The house currently only has an iron filter, im assuming a SmartChoice Eradicator. My research led me to believe I needed 1) An acid neutralizer 2) the iron filter (assuming smartchoice eradicator) 3) a 5-micron filter (bought ispring HC14-2PP with 5-micon filters 4) a softener (bought a 10% crosslink fleck 5600SXT 48,000) 5) UV light (bought ispring UVF55FS). Nothing installed yet.
Had a water company come out to test the water and made me question everything. Theyre recommending halo chlorine drip, halo h-crt-120 retention tank, halo h-is-100 iron/sulfer removal, halo h-sg-520 polishing filter, halo ion-9 conditioner.
Obviously thats much more expensive. Can someone help guide me on whats really necessary here? We are on a septic tank. Private property with acreage. 2 people 3 bathrooms.
Water test results below. Do I need to return what I bought and start over?
Is this a deep well? What are the specs? I would never get a proprietary system installed. The cost is going to be way more than DIY and then you are reliant on them for parts and maintenance. Unless you truly don't want to work on it yourself and have the money to pay inflated prices for someone else to do it.
I don't have any experience with E. coli or Coliform, but I do chlorine injection for iron bacteria. I also have a surface well that I'm going to put into service for garden irrigation - I haven't tested the water yet but I'm going to do a UV light there regardless.
I would sanitize the well. Well sanitizing (extra attention to 4 inch casing) | Terry Love sanitize is my procedure. It is more rigorous than most. It takes a lot of time.
When you do a coliform test, there are procedures needed to avoid a false positive. I think that a deep well would be unlikely to need coliform treatment ongoing.
On the other hand, chlorine injection, contact tank, filtration of sediment, and carbon to remove the residual chlorine will kill bacteria and remove iron. 7.5 ppm (mg/l) is a lot of iron. I don't know what a assuming smartchoice eradicator is. Perhaps you have a more generic description. I also don't know about nitrite removal, but I see the MCL is 1.0 and you have 2.0
You would follow that with the softener.
