Hi Everyone,
OK, I gathered some more info this morning. Some useful and some, well, maybe not as useful
The well lining is 6" diameter steel.
One issue is the hose attached to the well for hand watering is one of those expanding hoses that needs some decent pressure just to expand and this pump doesn't seem to do it. The wife is sold on this style of hose so going to a fixed length hose is not an option.
I checked the flow at a hose bibb from city water and well water hose bibb. Not exactly a fair comparison because the house hose bibb is connected inside with 1/2" PEX and the hose bibb attached to the well is a short run of 3/4" PVC. I used the same short hose (maybe a 10' length) for both.
House water hose bibb: 75 PSI and 5 GPM flow
Well water hose bibb: 35 PSI and 10 GPM flow
Of course the well water psi depends on the pump keeping the pressure up!
I jumped the terminals in the pressure switch to check the max pressure the pump can develop and it hit 45 PSI.
I tried adjusting the pressure switch. The max pressure did go up to about 42 PSI but the cut on pressure is still just above 25 PSI. I'd like the minimum pressure to be much higher than that.
So it seems that I should really give up on this pump and get one that can really do the job.
Valveman suggested the Goulds J5SH. But, that's a pretty pricy unit.
Any suggestions on shallow or deep well pumps that can use the 40-60 switch with a good flow rate (lets say 8-10 GPM)?
- Runs on 115 VAC.
- Uses a 40-60 pressure switch.
- Flow rate at least 8 GPM
- Not too expensive. Some recommended pumps are upwards of a grand! Is a max of $500 a reasonable limit?
Thanks again for all of the great information!
Larry.
