Capping cold water inlet on hot water heater
Ankle Deep
Michigan
I’m plumbing a seasonal cabin that will be winterized by gravity draining of the pipes. I’m modeling the system after my father’s cabin of 50 years. In his set up he removed the drain valve from the bottom of the hot water heater, inserted a dielectric nipple and attached the cold water supply. He also removed the cold water inlet nipple from the top of the tank and plugged the opening with a galvanized pipe plug. This system has been in place for over 20 years and the tank drains completely. Although, the of the galvanized plug makes me nervous (re: galvanic corrosion). In my system I plan to leave the original dielectric cold water inlet nipple on the top of the tank and will cap the pipe. Question?
To minimize the risk of corrosion. Should I use a brass or galvanized cap? I have both.
