I replace my vertical pressure tank yesterday. I expected a coupling between the tank and the cross, but instead there is an usual joint on the cross with two screws. I was able to loosen the screws and the pipe spins allowing me to separate the threaded fitting. When I got everything back together, it is slightly dripping from that joint. I assume there are some internal O rings, but I have no idea. Seems similar to a shark bite or quick connect but I couldn’t seperate the pipe from the cross. I am guessing the whole thing needs replaced but wanted to see if anyone had a suggestion to address leak first.
Thanks in advance even if you can confirm it is proprietary garbage that needs replaced.
Also ignore the teflon tape on it- I was just seeing if I could shove it in - there is no threading/groove exposed.
